Old 01-13-2019, 03:10 PM   #21
Keith 944
Keith 944's Avatar
Default Re: Super gas/comp/Street forums?
Originally Posted by Superstreet29 View Post
I do know if you are low on power dropping that cruise rpm gets unpredictable. And if you make good power getting it too high puts too many numbers in the timer. It’s a test and tune fine tuning point til you find what works on your car. I’ve been on at .001 with a Maxspeed, on at .10 same carb...you just have to have enough power to do it that soon or it will know the breath out of it and you’ll get a dip. I had a big motor combo that liked .001 and shift at .020.at 4300 and it worked well. Tried it with a smaller motor and it was a no go
^^^^ This
Every engine/combo is different. The key? Test, Test, and Test some more. The combo will show you what it likes, not the other way around...
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 01-27-2019, 01:48 AM   #22
mopacltd
Liked 124 Times in 44 Posts
4400 on launch, .050 on stop 2300 rpm, off stop 2.75, 10.90@147 and change at the stripe works for me
mopacltd is offline   Reply With Quote
Old 01-27-2019, 07:55 PM   #23
Shake & Bake
Liked 37 Times in 33 Posts
Lenny5160,
When running 9.90 I go on the stop at 0.001 and coast at 4150. I come off the stop in high gear. My 1/8 mile is 7.02 @ 131.83 compared to 1/8 mile WOT 4.66 @ 150.00
I lose 18-19 mph.
Shake & Bake is offline   Reply With Quote
Old 01-29-2019, 01:47 PM   #24
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
Originally Posted by Shake & Bake View Post
Lenny5160,
I lose 18-19 mph.
You're about the highest MPH S/G guy that I know of. Probably coming off the stop around the 330 cone.
S/ST 51
S/C 53
Old 04-21-2019, 06:18 PM   #25
Daran Summerton
Daran Summerton's Avatar
Liked 66 Times in 37 Posts
Can a double 0 dead on 122 mph car beat a 150 mph car?
72 cutlass
Daran Summerton is offline   Reply With Quote
Old 04-21-2019, 09:55 PM   #26
Keith 944
Keith 944's Avatar
119 Beat my butt more than once.
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 04-22-2019, 08:45 AM   #27
Daran Summerton
I have a 57 chevy sbc mini blower I have been kicking the S/ST idea around. This would be just a fun car trying to run 10.80s flatout footbraking it. I'm usually red on a pro tree. I would give it a shot unless someone talks some sense into me. Has anyone ever won without all the electronics? Im sure there would be a train following me to the lanes.
72 cutlass
Old 04-22-2019, 09:16 AM   #28
Keith 944
Keith 944's Avatar
Yes a former IHRA world champion in the 1090 class used to add weight, very hard to beat.very slow car
another guy from Atco runs our .90 series sometimes and uses no electronics and is very good
If I had a roll bar in my street /strip car I would use that as a back up without thinking twice.
Give it a try you might get hooked I see you are from Pennsylvania come run one of our mid Atlantic .90 races, the tree is set at .500 not @ .470 it would be perfect to get some seat time
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 04-23-2019, 07:46 PM   #29
doglover44
doglover44's Avatar
Liked 491 Times in 229 Posts
How can you run a 9.90 class with no electronics?
Jake Biermann
Old 04-23-2019, 07:51 PM   #30
Keith 944
Keith 944's Avatar
Go duckhunting and say a prayer
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
