Liked 9 Times in 2 Posts
Could you also run SS/FM ? (10.50 index @ 12.50 lbs per C.I.) No tear downs and weight looks the same. 302 cid × 12.50 lb = 3400- ish lb min. Same as your 9.0 x 380hp = 3420 lbs.
Liked 237 Times in 126 Posts
That's a fuel injected engine, so no. /FM is carburetor canted or inline valves. I think it's a Coyote, can't find a Cobra Jet for 2011.
Liked 408 Times in 35 Posts
It is a 2012 CobraJet 5 Liter naturally aspirated engine, not a 2011. This engine is rated 325 OEM / 300 NHRA, not 380. The 2013 and 2014 are rated higher since they have the large Acufab throttle body. My combo has the small OEM throttle body.
As for SS/FM this engine has EFI and 4 four valves per cylinder, both not allowed in modified. However the rule book does not specifically say "no overhead cams". The Coyote has 4 overhead cams and 32 valves. I will just continue to run Super Stock where I can adhear to my strict "NO CARB" diet.
George Wright https://9500rpm.com Last edited by George Wright; 05-01-2019 at 12:24 PM. Reason: I hate autospell on my "smart" phone |
#5 | |
![]() Here is a picture of my 82 Mustang GT that also has a 5.0 Coyote. I am in the process of putting a G-Force clutch-less 5 speed in the 82. I have plans for one of our guys to race the 82 at some NHRA opens or points meets later this year. ![]() This photo was taken at a CobraJet test session at Milan Dragway back in late 2012. ![]()
George Wright https://9500rpm.com |
#6 | |
Liked 786 Times in 201 Posts
Liked 373 Times in 131 Posts
Looks good George.
How did you mate the cogged water pump pulley to the 5.0 Coyote water pump ? Did you have to machine an adaptor ? ![]()
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
