Old 05-03-2019, 10:46 AM   #1
Adger Smith
Liked 880 Times in 311 Posts
Default Re: electric shocks on a supergas roadster ?
Tom,
If you were buying a set would you do the Koni/Lamb air or the Strange Electric?
A fellow Comp racer has a set of the air Koni/Lamb at a fair price.
Basic Question is Air over Electric any advantages?
Adger Smith (Former SS)
Old 05-07-2019, 08:46 AM   #2
Tom Goldman
Tom Goldman's Avatar
Liked 881 Times in 236 Posts
Adger , I would always go with the Koni or Lamb for all out racing and high HP applications.
The Strange shocks work well ,but you know that the range of settings is wider on the Koni .
I'd opt for the electric . Simpler system . the Strange shock uses a separate air compressor plus the air hose plumbing.
Both accomplish the same end result , I just think the Koni setup is a lot more sophisticated .
Old 11-18-2019, 12:36 AM   #3
rodrocket
I would be interested to see some of the settings the guys are running with the electric shockers
rodrocket is offline   Reply With Quote
