Old 05-16-2019, 02:49 PM   #11
George Wright
George Wright's Avatar
Liked 408 Times in 35 Posts
Default Re: 96 Mustang FGT/G
Originally Posted by ALMACK View Post
Looks good George.
How did you mate the cogged water pump pulley to the 5.0 Coyote water pump ?
Did you have to machine an adaptor ?
Alan,
Thanks. We machined an aluminium hub with several counter bored holes to bolt to the OEM water pump drive flange, then we bolted the plastic drive pulley over that in a separate set of threaded holes. The bracket to hold the electric motor is an extended / modified Mr. Gasket bracket. I have already fabricated 5 of these set-ups for various Coyote installs. If this keeps up at some point I will have to have the brackets water jetted.
George Wright https://9500rpm.com
George Wright is offline   Reply With Quote
