Old 05-18-2019, 01:06 PM   #41
Default Re: AMC Stocker suggestions
Originally Posted by pfordamx View Post
didn't there used to be a cam lift rule that allowed all cars under x amount of lift to go use x amount of lift.
No.
Just FWD and stock trucks are allowed .430 lift or factory, if greater.
That lift difference is negligible. If you're doing good, you can get all you're allowed at the valve. Somebody might have a .400 lift cam that you could roll and see how it comes up.
Old 05-20-2019, 06:48 PM   #42
pfordamx
Liked 7 Times in 5 Posts
if they check lift at the retainer than do you calculate for lash when ordering a cam since everyone is allowed solid lifters now and roller rockers if you lash the cam at .016 would your order a .426 lift cam instead of a .410 to try to get all of it because there not worried about the cam card just lift at the retainer?
pfordamx is offline   Reply With Quote
Old 05-20-2019, 06:49 PM   #43
Billy Nees
Liked 7,790 Times in 1,744 Posts
Cams are checked with zero lash.
Billy Nees 1188 STK, SS
