Liked 24 Times in 13 Posts
I have one in a '66 B-Body - all I had to do was cut off one of the ears on the bell housing like you mentioned.
Jeff Dudgeon '66 Coronet #10771 - bracket puke "the Flying Brick" |
Liked 263 Times in 68 Posts
Have you thought about using a blanket? It's easier.
John Dinkel 3295 STK |
Liked 239 Times in 114 Posts
On my 67 B body a CSR shield works great without modifying the tunnel . Do not cut the boss near the back of the case if you use a Turbo Action shifter because the cable bracket bolts to it . I do let the back of the engine droop down to allow easier access to the upper bellhousing bolts , have the shield in place while jacking the transmission into position .
The csr shield is nice but on my 69 a-body with a big block we had to modify the tunnel slightly
Liked 805 Times in 341 Posts
Fit really depends on the car. It ranges from not having to do anything to replacing the tunnel.
Liked 23 Times in 13 Posts
70 B-body DISASTER!!! So I called them, they said the design was for dragsters and if I wanted to fit it in a vehicle with a body that the tunnel will need to be messaged, biggest issue was the hump on the top towards the rear and the strap and mounts. If you have a pro trans you will have to cut it and you will no longer be allowed to re-certify that piece according to the rep
Frank Bialas 1570 STK |
Liked 18 Times in 11 Posts
I just called and talked with the "tech" line informed them my application was BB 69 B-Body. He informed me that I "might have to roll the body seam line at the floor" some to make it fit. Also, remove the casting tabs at the front as well and what ever I do NOT trim the shield in any manor as they will not "re-certify" the shield as any modification removes them from any liability.
They did state it was designed off a "dragster" application. Why not design around the tightest application first? Oh the joys.....
Eric Voigt 7425 STK |
