Old 05-27-2019, 09:48 PM   #1
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: Rear Main Seal Advice
What is the year of the block ? Is it a 2 pc or a 1 pc seal . Has the block been line honed ?
Old 05-27-2019, 09:50 PM   #2
jrstock
The block is a late model bowtie block with an adaptor to run 2 piece seal. It has been line honed.
jrstock is offline   Reply With Quote
Old 05-27-2019, 10:13 PM   #3
Alan Nyhus
Liked 799 Times in 236 Posts
One block I used had been line bored and the rear seal was leakage prone. Shortened the half of the seal that fits in the block until it fit normally. No offset and a dab of Valco aluminum silicone on the back of the seal and the parting lines.
We've seen a rash of rear main seal leaks lately with both the brown and blue seals.
"That'll never work....."
Old 05-27-2019, 11:44 PM   #4
SSDiv6
I have seen this happen a few times with the Bowtie block using the adapter. If the block has been align bored or honed, I remove the locating dowel and use the Allstar Performance rear seal adapter alignment tool P/N ALL26127.
https://allstarperformance.com/align...pter-all26127/
Old 05-28-2019, 11:46 AM   #5
carl hinkson
Liked 18 Times in 10 Posts
That does not work with a 400 main
carl hinkson is offline   Reply With Quote
Old 05-29-2019, 07:34 AM   #6
ron mattson
Liked 67 Times in 30 Posts
I have a slight leak like that also, spoke
With a distinguished gent from South Dakota
and he used a GM rear main recently on a engine
that had a similar issue and it cured the leak.
Ron Mattson 5015 STK
ron mattson is offline   Reply With Quote
