#1231 |
Those are the standard "grey iron" cap.
Todd Greene |
#1232 |
Liked 335 Times in 182 Posts
Todd check yet PM Dick
#1233 |
I saw that about the desiccant plugs? My PMs are wacky sometimes and I cannot respond but I did see this Thanks.
Todd Greene |
#1234 |
Dropped the block off today, it'll most likely be a week before I get it back to start machine work.
Todd Greene |
#1235 |
Liked 719 Times in 220 Posts
Seems to me that aftermarket steel main caps are available someplace for 4 bolt main 350's,must be better than the originals.Just trying to remember where I saw them.
#1236 |
They're everywhere, lots of aftermarket ones for sale.
Todd Greene |
#1237 |
Liked 976 Times in 311 Posts
Why put money into a questionable foundation.Cleaning block, Filling block, installing main caps etc.
#1238 |
Liked 557 Times in 217 Posts
30 years ago we sonic tested and Brinell hardness tested all small blocks.
The range from soft to hard was pretty significant.....and a hard block would easily make more power. Ideal was hard and decently thick cylinder walls..... .060 over was a lot..... Cylinder walls were just about always not consistant Core shift could be ridiculous You can usually see the cam being off center by the flat machined surface at the face of the cam hole...not concentric I had one engine I built at home that was so far off center it was silly The crank and cam centerline were way off center. So bad I had to get different rods. It was a 383 and I could not get clearance on one side for the rods to block even after grinding and the other side went right by with plenty of clearance..... Aftermarket and even Bowtie blocks are far better.... Just sayin!!!
#1240 |
I honestly don't see this as being questionable. How is a 400hp stock block an issue?
Todd Greene |
