#1 | |
Liked 431 Times in 224 Posts
https://www.summitracing.com/parts/ded-st1/overview/ https://www.jegs.com/i/Biondo/376/DDI-1068/10002/-1 I'd highly recommend the Biondo box if you go this route, since it can do RPM or time and the cost is equal. If you are using a MSD Digital 7 or Grid ignition, you can control the shift directly from that too.
S/ST 51 S/C 53 |
I went back and looked at my box and im curious, why wont the SLE work with STOP A still being utilized for TS and STOP B for shift? Since the SLE's cycle is completed at Transbreak termination.
#3 | |
That's actually what I do on my dragster, but it's mechanically injected and the car goes to dead idle on the throttle stop. There are other people doing it, but it's not a traditional setup.
S/ST 51 S/C 53 |
I am using an APD Max Speed Carb
I don't see how you could use a single delay box output to perform both functions, in that case.
Generally speaking, the SLE will be set to hold the engine at idle or near it. Throttle stop RPM is usually going to be 3700-4700 RPM. That STOPA output is either ON or OFF. How do the connected devices know which function is being commanded at what time?
S/ST 51 S/C 53 |
Thats what I was trying to figure out, I didnt say it couldnt be done or it could.
