#61 |
Liked 85 Times in 15 Posts
I got some parts for Christmas, so I plan on getting the short block together next week. I mounted my pistons up, and drilled the crank snout for the balancer bolt, a friend of mine faced the crankshaft flange for me. I balanced the assembly today, it needed 4 grams on the front and 9 grams on the rear, both on the crank pin side. My Dad will hone the block for me and I can start assembly.
#62 |
Block is honed and final cleaned, should have a finished short block tomorrow.
#63 |
I got the short block assembled, took a while to get the bearing clearance set. I was looking for .0025 on the mains, and the number 2 main was coming in at .0023, I was able to sand the back of bearing, really just cleaned it up and got the .0025 I was looking for, the rest went together good with no problems, I had .0022 on the rods. The picture of the main bearings # 2 sanded, the number 1 as produced. Now the work will start, the heads are next, thats going to take some time.
#64 |
Liked 705 Times in 219 Posts
What a nice immaculate clean place to work! I'm impressed with the quality of detail put into this project! Keep doing things right as you go along.
#65 |
#66 |
Liked 5,121 Times in 1,952 Posts
I have a feeling these Jones Boys won't be a secret too much longer ;-)..
#67 |
Liked 2,725 Times in 961 Posts
Very impressive young man!
#68 |
Liked 10,713 Times in 2,230 Posts
Things look great, keep it up!
When I looked that young, it was a few years before G I Joe was invented. |
#69 |
Liked 165 Times in 59 Posts
#70 |
Got started on the heads a while back, machined for screw in studs and guide plates. Installed the guides and honed them to size, and cut for seals. I then started on the intakes by unshrouding the chambers and hogging the bowls for the 2.020 seat. I then cut the intake seat and set height. The exhaust seats were next with the height set.
