Old 01-31-2020, 03:18 PM   #1
M420SSTAlley
Default Re: Et Genie 10.90
I think I'm going to set up the genie at 3/4 in closed on the first pass and then open it back up 1/2 an inch.
Sunday is test day so I will see what happens.
M420SSTAlley is offline   Reply With Quote
Old 02-03-2020, 08:57 AM   #2
M420SSTAlley
Well I made 4 passes
10.99 @121
10.80 @123
10.83 @122
10.87 @122
I'm liking this et genie. A few more runs and I think I can get a pretty good handle on it.
My new problem is trying to cut a light on the
.470 tree. Best I could do was a - 005 red on the. .500 tree.
I have a powerglide with a 1.76 1st. Im having issues with car moving backwards a touch when I get on the transbrake at an idle. If I raise the staging rpm then the car rolls forward. Most likely going to get a brand new glide built. Would a 1.87 1st help my reaction time a decent amount?
Old 02-03-2020, 11:29 AM   #3
gfbdiesel
Liked 2 Times in 2 Posts
adjust the band on the transmission. and raise the rpm's on the two step. go to 1000 or 500 of the stall. raise the rear tire pressure some to stop the wrinkle
gfbdiesel is offline   Reply With Quote
