Old 04-17-2020, 01:15 PM   #1
Jim Hanig
Liked 99 Times in 49 Posts
Default Re: H-I-J '76 Nova re-fit.
Originally Posted by Nmbr1GMfan View Post
This thing is such a dog in high gear you almost have to hold every gear as long as you can, if you shift 3-4 200rpm lower it will barely climb any rpm at all, just sits at 6800 and lumbers to the stripe. I don't know if it's the 1 goofy head thats on it or the cam. Hopefully we get some real dyno time at the end of the year to swap some parts and figure it out.
where is the cam center line 105? how much flywheel 35 lbs 3.29 low? 5.38 gear.
Old 04-17-2020, 02:24 PM   #2
Dyno
Dyno's Avatar
Liked 693 Times in 205 Posts
Running out of fuel?
Old 04-17-2020, 06:20 PM   #3
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
What does your RacePak tell you? Is it set up to log A/F and RPM? That would tell you what the fuel mix is doing at your shift points. Stock limits your cam lift but you can still move the valve events around.
Good luck.
Dale Shearon
68 Mustang 6394
Old 04-17-2020, 10:33 PM   #4
HP HUNTER
Liked 372 Times in 129 Posts
Piston to wall clearence?
Heads been evened up?
Who picked the lobes?
Respectfully I don't see how the MPH is any of the problem at this point.
1320/117=11.28
Old 04-19-2020, 10:55 AM   #5
Nmbr1GMfan
No, carries fuel pressure the whole way and has ample volume.
Todd Greene
