Liked 348 Times in 152 Posts
I imagine you've tried to rotate the converter?
Phil Molski PMR Performance S/C 1623 |
Liked 10,769 Times in 2,238 Posts
On a Mopar it will only bolt up one way without a lot of clearance
Liked 165 Times in 59 Posts
what transmission are you using?on my 904 the converter has to be clocked to match the flex plate,, gmonde
SB 727, all converters I have seen are the same for the B, RB, and SB 727
Liked 311 Times in 175 Posts
Sounds like the holes in the flexplate are off, check that?
Liked 693 Times in 205 Posts
I had the same issue. Before installing the 904 in my Challenger, I bench checked and marked the flexplate and converter to make sure the bolts would line up. Everything lined up perfect and bolted together. Once I bolted the flexplate to the crank and installed the transmission, the one odd bolt was extremely hard to get started. I think the process of torqueing the flexplate distorts it enough that the bolts are all hard to install.
Hacksaw
I would normally agree but Brand "X" converter came out and Brand "Y" will not bolt up. Just a guess Brand "Y" might be the problem. But it will be installed. |
