Liked 748 Times in 363 Posts
Well ya'll, I need to apologize, again.
Just spent an hour or more cruising back thru this thread. I was going up thru the Firebird years, and pretty much stopped, while talking mostly about the '71-'73 models. Occasionally mentioned some '74 models. But, never got into a lot of detail about any of 'em. Just got sidetracked, I suppose. I must talk about one in particular. I mentioned that it was a record holder, & even posted 3 record certificates for it, in J/SA, K/SA, & L/SA, along with a few pics. But, I need to post some race results showing the awesome performance this car had, at the time. The car, of course, is the Mulry & Aceves '74 Bird. Here are a few of it's #1 qualifying efforts. There were probably many others I don't know about. But, these will show what I mean. #1 @ - 1.599 https://www.dragracecentral.com/DRCS...r2008#indextop #1 @ - 1.579 https://www.dragracecentral.com/DRCStory.asp?ID=15141 #1 @ - 1.502 https://www.dragracecentral.com/DRCStory.asp?ID=62948 #1 @ - 1.437 https://www.dragracecentral.com/DRCStory.asp?ID=22233 #1 @ - 1.431 https://www.dragracecentral.com/DRCStory.asp?ID=25692 #1 @ - 1.413 https://www.dragracecentral.com/DRCStory.asp?ID=19620 #1 @ - 1.354 https://www.dragracecentral.com/DRCStory.asp?ID=10411 #1 @ - 1.106 https://www.dragracecentral.com/DRCStory.asp?ID=2733 Indy K/SA winner. https://www.dragracecentral.com/DRCStory.asp?ID=2310 #4 @ Indy with a - 1.274. https://www.dragracecentral.com/DRCStory.asp?ID=2312 Well, I think ya'll get the pic. This car was awesome ! As a side note, since this is a Pontiac Stocker thread, I think I count at least a dozen Pontiac V8 powered Stockers that made that 128 car '04 Indy field ! Last edited by oldskool; 08-15-2020 at 11:25 PM. |
Another nice '74 was the one Lindy Lindholm raced. It's the one that was stolen.
![]() It qualified well at lots of races. Let's start with a #1 @ the 2017 Winter Nats. Was the only car to qualify a sec under. Hey, I understand sandbaggin. But, it looks good to be #1 on the list. And lots of guys here are quick to congratulate some racers for being #1. https://www.dragracecentral.com/DRCS...r2017#indextop At the '15 Pomona Finals, he was 1.014 under. https://www.dragracecentral.com/DRCS...r2015#indextop #5 @ the '16 Winter Nats - 1.020 under. https://www.dragracecentral.com/DRCS...er=30#indextop Won class at this & many other races. https://www.dragracecentral.com/DRCS...er=30#indextop #4 & I/SA class winner @ the '16 Vegas Denso Nats. https://www.dragracecentral.com/DRCS...r2016#indextop https://www.dragracecentral.com/DRCS...r2016#indextop Highest qualified Pontiac & class winner @ Toyota Nats. https://www.dragracecentral.com/DRCS...UMMIT#indextop It was still running more than .900 under, last Sept. I suppose that if it hadn't been stolen, Lindy would still be racing it. https://www.dragracecentral.com/DRCS...r2019#indextop Last edited by oldskool; 08-07-2020 at 01:08 PM. |
Tho not as quick against their index, there are still at least 3 active '74 Bird Stockers, that I know of. And I may as well include Gary Riley's '74 wagon.
I think I've probably already mentioned all these cars. But, I'll mention them again here, to point out that the '74 4X head 400 is & has long been a very competitive engine. I'm reminded of the recent final round at the Mile-High Nats. It pitted Dwaine Davis in his '74 Formula, against Gary Riley in his '74 Lemans wagon. Gary won. https://www.dragracecentral.com/DRCS...r2019#indextop Then there is the Burton's "Grimace" '74 Formy, which recently made it's debut. And, there is the '74 T/A which is sponsored by John Clegg's Mission Garage, & is said to have been built by Forest Pierdolla. I think this T/A still runs an SD455 engine. Not sure. I suppose a '74 Bird could run a 400, a D-port 455, or if you don't mind running the high dollar SD heads, you could run the SD455. http://www.classracerinfo.com/Engine...1&MAKE=Pontiac http://www.classracerinfo.com/Engine...2&MAKE=Pontiac http://www.classracerinfo.com/Engine...3&MAKE=Pontiac That D-port 455 looks good, at the current 306hp factor. That engine has proven very competitive in several '73 Birds. No reason it wouldn't do just as well in a '74 model. Don't really know if the D-port 455 would be more competitive at 306hp, than the 400 @ 275hp. ![]() I do know that Michael Brand switched from the D-port 455 to the SD455, in his '73 Bird. It doesn't seem to be running as far under it's index, now. So, unless there is quite a bit of yet-to-be-found power in that SD engine, it appears that the D-port engine MAY be more competitive, at the current hp factors. Maybe we'll get to see if Michael can get a lower ET from his SD combo this year. Because of the rarity & price of those SD heads, I'd say there is not much experimenting that could be done. But, with the 4X D-port heads, a guy should be able to search for more power, from the heads. Because of the big chambers, many of those 455 4X heads have been junked. Those that remain are not in high demand. So, there should be some available for a decent price. Because of the legality of adding & removing weight, in order to change classes, I don't always know which engine all the Pontiacs are running. Looked up some Q-list numbers for Dwaine Davis & the Mission Garage '74 Bird. The times are usually a half sec under, or better. Both cars were at this div 4 race. Dwaine was .827 under, & Hunter was .755 under. Won't win all the heads-up races, but can win all other rounds. https://www.dragracecentral.com/DRCS...r2018#indextop Jeremy Romero ran .929 under in "Grimace". I assume that might win a few heads-up runs. https://www.dragracecentral.com/DRCS...er=30#indextop So, I'll have to say that a '74 Pontiac is a decent model Stocker to run. Last edited by oldskool; 08-09-2020 at 06:15 PM. |
For '75 model Pontiac Stockers, I can only think of 1 that is still active.
Up in the Northwest, Ryan Warter has a '75 Formy. Has been racing it for quite a while. Hasn't been long since he won the nat event up there, his 1st. It was an All-Pontiac final against Randi Lyn. https://www.dragracecentral.com/DRCS...UMMIT#indextop He was .940 under at this div 6 race. https://www.dragracecentral.com/DRCS...r2019#indextop May '16 - div 6 Nat Open doubleheader - Won 1st race - made semi-final in 2nd race ! http://classracer.com/classforum/showthread.php?t=62151 6/5/16 - div 6-3 - #1 - 1.066 under https://www.dragracecentral.com/DRCS...r2016#indextop 8/7/16 - NW Nats - Stock R/U, in another All-Pontiac nat event final ! https://www.dragracecentral.com/DRCS...r2016#indextop 9/17/16 - Stock Challenge - Winner, in another All-Pontiac final, against Brad Burton, again ! https://www.dragracecentral.com/DRCS...er=30#indextop 8/6/17 - NW Nats - 3rd place - But hey, he had a pretty good 3-year run, at the NW Nats ! https://www.dragracecentral.com/DRCS...er=30#indextop 5/4/19 - div 6-1 - #2 - 1.129 under https://www.dragracecentral.com/DRCS...r2019#indextop Last edited by oldskool; 08-10-2020 at 06:08 AM. |
For '76 model Pontiacs, I can only think of 1 Stocker. It was raced by Mike Morgan for several years. Mike won his class at the 2014 US Nats. I'll look up that win & some other results for the car.
https://www.dragracecentral.com/DRCS...r2014#indextop He was #97 @ .943 under that year. https://www.dragracecentral.com/DRCS...r2014#indextop Looks like Mike had it tuned up for Indy, back in July. He went .924 under at this div 3 race. https://www.dragracecentral.com/DRCS...r2014#indextop Was R/U in K/SA @ the '13 US Nats. https://www.dragracecentral.com/DRCS...r2013#indextop Also made the Indy field in '12, @ .945 under. https://www.dragracecentral.com/DRCS...r2012#indextop @ Indy '11, he won the K/SA class & qualified 1.032 under. I've read that he ran Parsons & Myers power. https://www.dragracecentral.com/DRCS...r2011#indextop https://www.dragracecentral.com/DRCS...r2011#indextop Well, ya'll get the picture. The car was quick enuff to be competitive. https://autoimagery.photoshelter.com...DIl7g--&GI_ID= https://autoimagery.photoshelter.com...DIl7g--&GI_ID= I think Kevin Love bought the car from Mike, right after Indy, '14. He was 1.105 under at the '14 Fall Classic NO. https://www.dragracecentral.com/DRCStory.asp?ID=293473 In '15, he was #1 @ this div 6 race, with a .962 under. https://www.dragracecentral.com/DRCS...r2015#indextop At the Lucas Oil Nats, he won K/SA & was .903 under. https://www.dragracecentral.com/DRCS...r2015#indextop https://www.dragracecentral.com/DRCS...r2015#indextop @ the Fall Classic NO, he was 1.113 under. https://www.dragracecentral.com/DRCStory.asp?ID=306741 Still running strong last year at this div 5 race. #3 @ 1.031 under. https://www.dragracecentral.com/DRCStory.asp?ID=356180 Last edited by oldskool; 08-08-2020 at 05:47 AM. |
When it comes to '77 Pontiacs, there are lots of body choices.
Thru the years, there have been LOTS of '77-'78 Bird Stockers that have been very competitive. BUT, because of the big hp factor on the '77 400, when running a Bird body, non-Bird bodies are obviously much better choices. There have been quite a few '77 Lemans Stockers. I think Dave Ribeiro still runs one that Bob Michael built. And Wayne Larsen runs one that has been passed around. The '77 GP that Don Himes ran is still active. As far as I know, Bob Michael has the only '77 Catalina that has been built. As I've probably mentioned, I'd like to run a Can Am clone. Just think one of those would look cool, as a Stocker. As far as I know it would be another one-of-a-kind. I assume that for those who wanna run a '77 Bird, the 350 engine might be a little more competitive. But, even the 350 gets a 4 hp handicap, if you run it in a Bird Stocker. Mike Morgan has certainly done well with it in SS, @ 246hp. http://www.classracerinfo.com/Engine...3&MAKE=Pontiac In non-Bird bodies, the base 400 is competitive, at it's current 260hp factor. How long will it remain at 260hp ? I suppose that depends on whether anybody runs quick enuff with it to make noise. http://www.classracerinfo.com/Engine...4&MAKE=Pontiac My guess is that if you wanna run a 400 powered Bird, it would be better to run it as a '78 model, using what Mark Yac calls the "big cam" engine. It's only 7hp more, 290hp vs 283hp. http://www.classracerinfo.com/Engine...7&MAKE=Pontiac From lookin back thru the race records, I've seen that several guys have switched between claiming a '77 & a '78 Bird. I assume this is so that they could run the most competitive combo, when considering the NHRA hp factor for each engine, at the time. Have probably asked this, but don't remember the answer. The '77-'78 Pontiacs can run the larger Q-jet, which street guys call an 800cfm. The '74 model (except for the SD455 engine) Pontiacs must run the smaller 750cfm Q-jet. There has obviously been LOTS of Q-jet testing, thru the years. So, aprox how much ET gain would the larger Q-jet make, on similar 400 Pontiac Stocker engines. http://www.classracerinfo.com/Engine...1&MAKE=Pontiac There have been so many competitive '77-'78 Bird Stockers, thru the years, it's hard to pick just 1 or 2, or even just a few. But, just from the research I've done, Dave Ribeiro's Bird comes to mind. It held a nat record for a couple of years. Out on the West coast, Bill Edgeworth's Bird was also a record holder. I can remember when Ryan Warter raced it & was trying to help sell it. Anybody know if it is being raced nowadays ? So many more come to mind. You can go to DRC & look at the Stock Q-lists from the US Nats, & find lots of quick '77-'78 Birds. Seems I remember seeing a Don Holmes Bird high on the Stock Q-list. Won't try to name 'em all. At the 2000 US Nats, Don Holmes was #2 @ 1.269 under, & won K/SA, in a '78 Bird. Dave Edwards was #5 & won L/SA, in a '78 T/A. While we're there, Danny Ashley won N/SA in a '74 GA. https://www.dragracecentral.com/DRCS...r2000#indextop https://www.dragracecentral.com/DRCS...r2000#indextop The Indy Q-lists & class winner lists, are always very interesting to me. I like the '03 Indy lists. Dave Edwards had the highest qualified Pontiac. He was #17 @ 1.133 under. Also won his class. There were some other notable Pontiacs on those lists. Don Himes won his class, in his '77 GP. Scott Burton won his class, as did Mike McGinley. The Biondo Bird was on the Q-list, as was Kyle Riley & Bill Rink. https://www.dragracecentral.com/DRCS...r2003#indextop https://www.dragracecentral.com/DRCS...r2003#indextop @ Indy '08, apparently Ryan Warter drove Bill Edgeworth's '77 to the #10 position @ 1.196 under, and won his K/SA class. That was also the year Todd Hoven was #7 & won G/SA, with a '72 GTO. https://www.dragracecentral.com/DRCS...r2008#indextop You can add 9 pics to a post. I may see if I can find pics of 9 good '77-'78 Bird Stockers, to post. Some of these are the same car, with different owners. Most of these cars have been mentioned & pictured in this thread. But, here they are, again. Some guys may see this who would never look thru the entire thread. Anyone with pics of '77-'78 Bird Stockers I haven't mentioned, please post info & pics of those Birds. Also, anyone who'd be willing to give us the history of any or all these cars are welcomed, & even encouraged to do so. Between all these Birds there have been many race wins, class wins, & records set. They are part of Pontiac Stocker history. As a real Pontiac freek, I am very proud to post info & pics of these cars ! ![]() PS: As ya'll can see, white seems to be the preferred color for '77-'78 Bird Stockers. Last edited by oldskool; 08-09-2020 at 07:10 AM. |
Sometimes I am amazed at Pontiac drag racing info I can find, just by doing a Google search. I have often said to my wife: "Google knows everything." .
https://www.hotrod.com/articles/hppp...rts-nationals/ That article called my attention to the nat event at Englishtown, in 1998. I may have already posted about it. BUT, in light of talking about competitive '77-'78 Pontiac Stockers, there may not be a better single race which is more connected. Carol Yacavone was #8, followed by Dave Ribeiro @ #9, Don Himes @ #22, Dean Ribeiro @ #27, John Rodnite @ #36, & Bill Groton @ #92. Not familiar with those last 2 names. https://www.dragracecentral.com/DRCS...r1998#indextop AND, check out the class winners. L/SA, M/SA, N/SA, O/SA, P/SA. https://www.dragracecentral.com/DRCS...r1998#indextop Checked out the '98 Indy class winners. Bob Michael was #12 @ 1.034 under, & won M/SA, in a '78 T/A. Next Pontiac on the list was the Don Holmes '78 Bird. There were also several other Pontiacs that made the 128 car field. https://www.dragracecentral.com/DRCS...r1998#indextop https://www.dragracecentral.com/DRCS...r1998#indextop Don't have lots of pics of the non-Bird '77's. I do have pics of the '77 Lemans that Bob Michael had, which Dave Ribeiro has now. Also have 3 pics of the '77 Lemans that Kyle Riley had, then, at some point Jack Larsen had, which Wayne Larsen now races. IIRC, the 1st car was wrecked & Kyle used another body, to put another Stocker together. Those Kyle Riley cars show up on lots of DRC race results. Can't resist mentioning the '04 Indy Stock Q-list again. There were about a dozen Pontiac V8 cars that made the 128 car field. 5 of those were '77-'78 models. Kyle Riley's '77 Lemans was one of 'em. https://www.dragracecentral.com/DRCStory.asp?ID=2312 @ '05 Indy, Kyle won the N/SA class & Don Himes won P/SA. https://www.dragracecentral.com/DRCS...r2005#indextop I think Bob Michael won class @ Indy with his Lemans. There have been several '77 non-Bird Pontiacs make the field at Indy. Bob's '77 Catalina is one of 'em. When I find 'em, I'll post some of those Indy results, here. 5/5/18 - div 3-1 - #1 - 1.064 under. https://www.dragracecentral.com/DRCS...r2018#indextop 8/30/19 - US Nats - #107 - .968 under - R/U in L/SA. https://www.dragracecentral.com/DRCS...r2019#indextop https://www.dragracecentral.com/DRCS...r2019#indextop Bob Michael was R/U in class @ the '12 US Nats, & won class in '13, over fellow Pontiac racer Don Turk. Pontiac also picked up class wins that year in D/SA, F/SA, & G/SA. https://www.dragracecentral.com/DRCS...r2013#indextop Gonna post the pics I have now, then come back & swap out some, if I come across more. All who read this are welcome to post any good pics you have of non-Bird '77 Pontiac Stockers. Last edited by oldskool; 08-14-2020 at 01:42 AM. |
