Old 07-01-2020, 07:14 PM   #211
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: Nova stocker project.
Go gettum Alan...
Rich Taylor
I/SA - 321
Old 07-11-2020, 06:30 AM   #212
Alan Nyhus
Liked 799 Times in 236 Posts
Trent Gusso @ Dakota Speed Lab worked his magic on the control arms. Thanks, Trent!
"That'll never work....."
Old 09-25-2020, 08:19 AM   #213
Alan Nyhus
The AFCO double adjustable front shock update was worth doing. Thanks to the guys at AFCO for working with me on the valving for my application.
Smoothing things out (up) and controlling it better (down) really helped....worth a couple hundredths. -Al
Old 09-25-2020, 08:30 AM   #214
Alan Nyhus
We hit two important goals this season.
With the G/SA index being 12.00 (uncorrected), any run in the 10's would both get the car in the '1 Second Under Club' as well as being it's first pass in the 10's. We were close earlier this season at Earlville, Iowa, running 11.04. At Pierre, S.D. it went 11.155 on the altitude corrected 11.15 index.
After the front end tweaks and more digging for whatever crumbs we could find, it responded some more. Again at Earlville over Labor Day, it went 10.955 on Q1, 10.947 on Q2 and two 10.96's in eliminations.
Old 09-27-2020, 11:39 PM   #215
killintime6968
Liked 91 Times in 29 Posts
Happy to see you got it flying . I got mine out to two races in the last month after a 2 year hiatus with health issues. Had nothing but trans issues that had started back in 18. I had rebuilt the trans but never got to test it till now. Same problem was there in mid August. Went through the trans again and could not see anything really wrong other than some slightly marred teeth on the sliders. Went to last race of the year for us and problem was still there. Made for a long tow home. Sitting at work Monday night I suddenly realized what the problem was. I put the shift levers on incorrectly. Made 1st gear actually 2nd and so on. So I was actually trying to downshift on launch and third was forth. What a @@ I am. Oh well , now time to get ready for next season with a new trans and clutch. Sorry for ramblin on.
Bruce Cameron
68 Nova 396 E/S
68 Camaro SS/? ex Checkmate Modified
killintime6968 is offline   Reply With Quote
Old 10-01-2020, 09:45 PM   #216
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
Al,,,can you give your contact at afco?I have the same set and I am maxed out on adjustment for compression dampening, it's still bouncing
Thanks gmonde
Old 10-01-2020, 10:53 PM   #217
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Thanks gmonde
I always talked to Eric at AFCO
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 10-11-2020, 01:55 PM   #218
Dyno
Dyno's Avatar
Liked 693 Times in 205 Posts
Randy at FastShocks can fix that for you.
Dyno is online now   Reply With Quote
Old 10-11-2020, 06:59 PM   #219
gmonde
gmonde's Avatar
i had called both places ,,sorry parts are no longer available and afco will sell me new shocks , i guess these are like software programs ,, these go unsupported no mater how much you spend ,, i will take them apart and do what needs to be done,, thanks for you suggestion's
gmonde
Old 10-11-2020, 08:09 PM   #220
Stephen & Horace Johnson
Liked 163 Times in 53 Posts
gmonde
just got my afco back from randy and they fixed mine....
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is offline   Reply With Quote
