Liked 20 Times in 16 Posts
Time to replace my trailer tires. Any suggestions on tire brand without breaking the bank. Also knowing the life is only 6-7 years. My current tires are Hercules Power STR ST225/75 R15 Load range E. Starting to crack between the treads now which they are 7 years old. Trailer weight loaded is approx. 10K lbs. Thanks in advance for opinions.
Drew Wonderly SST 159 |
Liked 3,174 Times in 971 Posts
Had a lot of trouble with Goodyear Marathons but tried their newer Endurance tires on my trailer. 10K miles and they still look great; no bulging sidewalls and with a higher load range than the Marathon I think it's a good economical tire. If you want better then you probably need to switch over to the 16" combinations. BTW, unless they are babied and keep out of sunlight most of their lives 5 year replacement is recommended.
Liked 800 Times in 337 Posts
Like Jim and many others I have had troubles with Goodyear trailer tires in the past.
However I have not heard anything bad about the new Goodyear trailer tires and they have been out for a while now. I don't think I have ever had a trailer tire blow out that was less than three years old, except for the earlier Goodyears. |
Liked 162 Times in 45 Posts
There are now load range “f” tires available. They are a very heavy and look like trailer tires. Call Greg Luben at L&S Trailers in Hawthorne Fl.
Liked 200 Times in 62 Posts
My tire guy told me that the Carlisles were real good again. He's never steered me wrong so I tried them 2 years ago and he was right. No issues yet in about 5K miles, they still look new!
Don’t waste your money, go to 16” wheels. Way more options for tires.
Joe Martens AA/Stock 3969 |
Liked 969 Times in 307 Posts
And what if you can't fit them on trailer?????
Well then I guess you would have to stay with a 15" tire, but I would imagine there is a 16" that would fit.
Before I found load range “E” and long before the load range “F” I shopped for 16 inch trailer tires. The 16 that was the same height as a 225/75 15 has a significantly lower load rating pound wise than a 15 inch load range “E”. Load range “E” almost cured my trailer tire problems and I’m certain these new “F” tires will do the job. They are beasts, they look like low boy trailer tires.
#10 | |
