Old 11-06-2020, 07:25 AM   #1
Robbie Welch
Liked 262 Times in 124 Posts
Default Re: SST Starting Point
Yep that's how I do it. Leave the line go on the stop come off the stop and air shifter hits at 6800.Then the games begin. There's a lot of finish line strategies played out. When I was running the 3 speed trans the TS and the 2nd gear shift where every close to one another. That's not and idea situation
Old 11-06-2020, 02:04 PM   #2
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
You'll have more MPH if you shift on RPM after you come off the stop. That's how I'd do it if I were you.
I'd probably stay wide open a bit longer, turning the stop on around 0.300 to get the car moving and allow you to be coasting on the stop through the 60' timer. I use 0.500 with my car that runs right at 6.40 in the 1/8 mile wide open.
S/ST 51
S/C 53
Old 11-06-2020, 09:42 PM   #3
Keith 944
Keith 944's Avatar
You have some good advice from some really good racers, take their advice.
My 2 cents, use it and test,test,test. every car-combo is different. it will show you what it likes. more important than mph or anything else is repeatability. there is a sweet spot for cruise rpm don't go too low....
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 11-06-2020, 10:37 PM   #4
J518
Liked 151 Times in 37 Posts
You have a really close setup to mine. I'm 2815lbs, 4.88 rear, and closer to 700-725hp. At 1800DA in the 1/8th I ran 6.25.
So shift wise don't waste your time on shifting into high while on the stop. 2800lbs is still alot of weight and you are not going to break the tires loose in low.
I come on the stop at .375 and at topeka with 2100ft DA I had 1.95 in the stop and ran a 10.906. With that hp I think you should aim for higher dead stall rpm. I would shoot for 4600-4800rpm while on the stop.
Best of luck! Never understood why we like more complicated racing haha
J518 is offline   Reply With Quote
Old 12-03-2020, 09:19 AM   #5
StompNDump
Just wanted to say thanks to everyone for the info. I managed to go some rounds but had luck on my side also. Struggled with getting 60fts to repeat and 330. 2 passes would be close then the next would be a pick up or slow down in 60 ft or 330's. Im thinking the carb may not like the throttle stop, in the morning cool air there was a slight hesitation when coming off the stop, this later cleared out as the weather warmed up. Time to start testing more.
StompNDump is offline   Reply With Quote
Old 12-03-2020, 05:34 PM   #6
Regan Wilson
Regan Wilson's Avatar
Liked 134 Times in 70 Posts
Where did you run? What race? Local or something else
Regan Wilson is offline   Reply With Quote
Old 12-03-2020, 06:39 PM   #7
Keith 944
Keith 944's Avatar
i don't know what your #s are but if they are close to or before your 60' it will change. this happens a lot with 1/8 mile because our #s are less then the 60' . example 1.60 in throttle stop duration at .01 out and sixtys are 1.90 when you change the stop it will also change 60' numbers.....
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
