Nice car. Wish they had them like this in Ohio. I’ll check into some shipping prices though.
Liked 354 Times in 120 Posts
Next eco tech tip, If you put a oil pressure gauge on these motors you would faint. We broke our first gauge it only went to a 100 psi. This oil pump is crank driven on the front of engine, and the relief valve is easily accessed on that cover by simply pulling out the hex plug and trimming the spring. Remember it has oil pressure chain tensioners so don't get cared away. These motors crush the oil filters from flowing a lot of oil so put name brand on, we have had good luck with GM ones. One thing with a stick do you have to have a sfi flywheel? One more quick tip we run a wire to the bottom side of the cooling fan relay to ground it with a toggle switch to run the fan to cool it down anytime. Tom
Tom Meyer 5240 SS Stock ??? Last edited by Tom Meyer; 11-08-2020 at 11:36 PM. |
I would definitely use an SFI flywheel. That is one thing I wouldn’t scrimp on.They are available in the aftermarket.
#4 | |
Liked 5,121 Times in 1,952 Posts
No SFI flywheel, clutch , or bell housing protection required..Of course, no 2 year belts either ;-)
Liked 7,731 Times in 1,739 Posts
So, I went to Island yesterday. The place was PACKED!!! I used the HP Tuners package to raise the speed limiter and raise the RPM limiter. That worked fine, the car ran the index again at just under 87 MPH which I was quite happy with as the air was about 1000' worse than the last time I was there ( almost 80* in NJ in November! Ya gotta love global warming!).
After using the HP tuners deal, I have definitely come to one conclusion, giving me a laptop and a programmer is like giving a chimp a thermo-nuclear device. If anybody out there has ANY experience with this stuff, I wouldn't say no to some advice. Thanks in advance.
#6 | |
Liked 971 Times in 308 Posts
#7 | |
Sponsor
Liked 714 Times in 120 Posts
They do a very good job of step by step hand holding and basic explanation of the HP Tuners Software and how to use it. If you don't want to spend the $$ then I suggest that you spend some time in your driveway playing with the program. I can answer most questions. I will post up a sample log later. Robin
STK 308 SS 3088 |
I second "The Tuning School" Bob Morreale does a great job. Get a wideband and go to work on fueling and timing. If you have access to a chassis dyno you will learn quickly. Look for anything that will restrict timing like coolant temp or inlet air temp, those will greatly affect consistency.
https://www.youtube.com/c/TheTuningSchool/videos
Todd Greene |
