Liked 633 Times in 88 Posts
1983 white Malibu wgn
-.85 anywhere Indy qualifier and class winner 2020 Parson 305 short block ATI balancer Moroso oil pan Total seal ring pack Heads up cylinder heads PAC springs Roller rockers Stahl step headers year old 16 volt battery ATI converter 45 runs McClay 200 trans 45 runs Mark Williams front brakes aluminum drum rear brakes QA1 front and rear double adj 5 gallon fuel cell, newer pump and lines McDonald Q jet 12 bolt rear end strange axles, spool and gear. Strange master cylinder MSD coil,distributor, and box Auto meter gauges Folk brake pressure switch Moroso Cool can CSR water pump ARC switch panel Turbo action shifter Center line wheels 6 point roll bar car also comes with spare 1978-1979 front grill/clip painted to match. And boxes of spare parts, rocker arms, push rods, gaskets ect $12,499 turn key $10,000 mins McClay trans and converter Great stock eliminator starter car. 517-605-8309 Chuck Downing
Charley Downing 3548 STK |
