Old 12-15-2020, 10:20 AM   #1
Dwight Southerland
Dwight Southerland's Avatar
Liked 775 Times in 193 Posts
Default Re: Not for Nuthin' But Close!
Dwight, I couldn't have done many of the things that I have done in my life without the help and support of friends.
All of us are in that category! But doing it together is where the value is (including the fun!).
Old 12-15-2020, 03:17 PM   #2
JakeB23
Liked 17 Times in 3 Posts
We might need to start a new thread regarding HPtuners. It might be more fitting on Classracer since dial in racing is going to have a pretty different tune rather than a fast street car tune, which seems to be moderately common on the repository.
My question is, how "simple" can I make a car for the strip only? Lock timing, RPM only shifts, no spark advance or retard, No IAT adjustments, etc..
JakeB23 is offline   Reply With Quote
Old 12-15-2020, 05:30 PM   #3
Doug Hoven
Liked 828 Times in 163 Posts
Basically what I did was find out what was varying run to run and locking it out. The timing is now locked because it did some wacky stuff from run to run before. I also disabled the knock sensor because even though it wasn’t pinging, it would randomly take timing out to try and mess with the air fuel ratio. I put it in open loop so it didn’t try and tune itself going down the track, and the shifts are set by rpm.
