Old 01-21-2021, 11:36 AM   #1801
Nmbr1GMfan
Default Re: H-I-J '76 Nova re-fit.
Originally Posted by Greg Reimer 7376 View Post
I've heard some people say that they have assembled short blocks that will spin over on the engine stand and only need 3-4 foot pounds of torque to rotate the crank. Of course, this is without the heads on, but less torque to turn would equate more power left over at the other end of the crank.Best wishes with this latest incarnation and for a great season for you guys!!
Greg, I'll try to measure it before the valve train goes on.
Todd Greene
Old 01-21-2021, 11:17 PM   #1802
Nmbr1GMfan
Greg, frank, I don't know if this is the way to do it but...
Todd Greene
Old 01-21-2021, 11:23 PM   #1803
Nmbr1GMfan
A few more things checked off the list. I don't know how everyone else lines up the gaskets to the heads and manifold but here's how we did it.
Todd Greene
Old 01-22-2021, 11:15 AM   #1804
Greg Reimer 7376
Liked 727 Times in 221 Posts
Cool Re: H-I-J '76 Nova re-fit.
I used an old fashioned 40 year old long torque wrench that had the scale right under the handle, with a long pointer to give a reading off the scale. I actually haven't seen those for sale for a long time.The click type as initially released by Snap On in the early '70's has consigned all the spring type torque wrenches to obsolescence. One of my 327 short blocks few years ago could actually easily be turned by hand by gripping the harmonic balancer and spinning it pretty easily. It took around 5 or 6 pounds/feet to turn it with the old style torque wrench. Probably a click type inch pound wrench would be a good idea.I'm sure that by your description of this engine assembly that you've found some improvement.
Old 01-22-2021, 08:50 PM   #1805
Nmbr1GMfan
It's back! See if we can get it painted tomorrow.
Todd Greene
Old 01-22-2021, 11:31 PM   #1806
Nmbr1GMfan
I tried a kinder gentler approach to seal installation, it was almost too easy.
Todd Greene
Old 01-23-2021, 12:06 AM   #1807
Nmbr1GMfan
The clutch is back. Really not sure where to mount this accumulator and it won't happen now but collecting parts to eventually switch to a grid.
Todd Greene
Old 01-23-2021, 11:41 AM   #1808
HP HUNTER
Liked 373 Times in 129 Posts
I will interested to see how this one MPHers. Hopefully the upper valve cover studs don't break out of the casting.
Old 01-23-2021, 01:15 PM   #1809
Gary Anderson
You don't miss too much do you?
Gary Anderson is online now   Reply With Quote
Old 01-23-2021, 01:24 PM   #1810
Gary, Fairly obvious with those gaskets..Surprised nobody mentioned it before now ;-)
Todd, Nice working conditions..We should all be that lucky :-)
