Old 02-09-2021, 12:22 PM   #1
George Wright
George Wright's Avatar
Liked 405 Times in 35 Posts
Default Re: H-I-J '76 Nova re-fit.
Where is the release for the two step? Is it on the clutch pedal? If so, it looks like it is at the bottom of the pedal linkage. Move the release to the top of the pedal. The graph shows the engine spiking to about 7000 rpm before the drive shaft moves. This means all the counter weights in the clutch are engaging and making your clutch hit hard. Also the engine RPM graph should not pull down to a sharp V on the shifts. It should be more of a U shape on the gear change pull down. Take out some base.
George Wright https://9500rpm.com
George Wright is offline   Reply With Quote
Old 02-09-2021, 12:55 PM   #2
Nmbr1GMfan
Exactly, now I just need to get it done.
Todd Greene
Old 02-09-2021, 02:21 PM   #3
FED 387
Liked 333 Times in 180 Posts
Todd---JUST before launch it appears that the car is moving forward just a touch ever so slight (rolling????)---or is the clutch dragging the car thru the lights--Its not sitting at a dead stop and then BAM launch--- look at around 1:29 on the video--is the line loc on or did Autumn take her finger off and is just sitting waiting for the tree to come down to the last light??? FED 387
Old 02-09-2021, 02:34 PM   #4
Nmbr1GMfan
Line lock is not on and clutch need just a tad more air gap.
Todd Greene
Old 02-09-2021, 07:40 PM   #5
FED 387
THat's what I would of thought---Car looks awesome---the whole program is coming together--Regards Dick
Old 02-09-2021, 08:26 PM   #6
Nmbr1GMfan
Forward progress. We're loving it!
Todd Greene
Old 02-20-2021, 08:09 PM   #7
Nmbr1GMfan
Todd Greene
