Old 02-21-2021, 12:16 PM   #1
J518
Liked 151 Times in 37 Posts
Default Re: 79 Malibu- Stocker-Stick Shift
Looking back, can't believe we missed the main hoop support bars but thankfully it was brought to our attention before the interior was in.
So thank you!
We made quick work with a saturday afternoon and added two bars.
J518 is offline   Reply With Quote
Old 02-21-2021, 12:19 PM   #2
J518
To wrap up our afternoon we settled on our fuel cell location. Made our fuel cell band before running out of enough material for a on the second one.
Old 02-21-2021, 12:23 PM   #3
J518
Can we run a hand brake for our park brake? The stock pedal brake runs into our roll cage and its also a bear to get the cable ran to it.
Old 02-21-2021, 09:47 PM   #4
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
You can remove the parking brake. Parking brake is optional per rules.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 02-23-2021, 03:16 PM   #5
J518
Sean
Yeah, I guess to better answer my question I should ask. Would they scoff at a handbrake in a car that did not offer/come with one stock?
Old 02-23-2021, 10:12 PM   #6
Probably go unnoticed, unless you have a bunch of wires and solenoids hooked to it.
Here's all you need for a stick car ,to warm it up and set the timing:
Old 02-28-2021, 09:58 PM   #7
J518
Well I wasn't able to make it back this weekend due to work and probably wont for a few more but dad started on the new dash cover, along with mounting the "control center"
I made the panel without measuring under the dash myself so modifications had to happen. The terminal strip closest to the firewall had to be moved in order for the panel to fit. With the heater core panel easily removable dad come up with a quick solution.
Try not to knock his flip phone images too bad!
