Liked 43 Times in 29 Posts
Either will work, however the tape is much neater
Mark Ruset 2048 STK |
Liked 272 Times in 108 Posts
Ive always had good luck with tape, but now reading can cause water pump housing to crack.
Liked 397 Times in 153 Posts
Only if you overtorque it. Keep in mind that teflon is a lubricant as well as a sealant.
Phil Molski PMR Performance S/C 1623 |
Liked 928 Times in 263 Posts
I prefer tape. Neater. And I can control the thickness.
Liked 264 Times in 69 Posts
I like tape.
John Dinkel 3295 STK |
Liked 1,607 Times in 584 Posts
In the aviation world, the use of Teflon tape is prohibited due to the potential of the tape deteriorating and slivers getting into the fuel, hydraulic or other systems.
Since AN fittings do not seal at the threads, but rather at the flare, mechanically, metal-to-metal, there is no need to use sealant on the flare end. The only time you need to use sealant is on any fittings with pipe threads. The proper process to use the liquid Teflon sealant is to apply a single bead all around the thread, keeping it away from the first two threads and the end of the fitting. A good indication that just enough sealant has been applied is when a small amount of sealant has been pushed out of the fitting all the way around the threads. The best fitting sealants that I recommend are Permatex 59235 and Loctite 567. They are fuel, oil and ethanol resistant and great with high pressure plumbing such as brake caliper fittings. |
Liked 20 Times in 12 Posts
Bingo
