Old 04-03-2008, 09:40 AM   #1
Dick Butler
Liked 32 Times in 19 Posts
Thumbs up Re: Automatic Horsepower Factoring System
Reward performance. Pay Class winners Same as Eliminator or more. May need to limit number of classes,.STOP creating more classes for fewer cars which adds to bracket method of racing. Consider going to 32 SS and 32 Stock classes. Fit the structure by adjusting your combo for the good of the BIG picture.
Stop factoring by ADDING hp.
Adjust Over factored combos by REMOVING HP. (only till close then let racers make hp ) Use only Motor winning classes as standard then adjust.
Consider late versus early chassis factor(GT aerodynamic versus early BOX cars) for adjustment.
Cut index of all classes to make up for years of performance enhancing parts .
Lynn This would include Pontiac as they would decrease HP for cars which really dont win class till the HP is appropriate for parts available....
Bart.... The Money card is always there. Anyone can run eliminator but the question is are any of the classes cheap. What is cheap? Does NHRA owe it to everyone to make it cheap?make it for everyone?
Old 04-03-2008, 11:05 AM   #2
Harry 6674
Default Re: Automatic Horsepower Factoring System
Good post Rich. throw away the shoe polish tuneups and race. Reward the fast cars, thats the way it should be. It is drag racing not brake light racing. I'm not a high roller but but I would rather be beat by a faster car than out braked at the lights. I was racing in the 60s and it was a lot of work but I feel more rewarding.
Harry 6674 is offline   Reply With Quote
Old 04-03-2008, 04:29 PM   #3
Lynn A McCarty
Lynn A McCarty's Avatar
You gotta make the rules the same for everyone or it is all an exercise in futility. This required the break out rule to "fix" in the first place. (Dick, who says we dont have the replacement parts? We have all the same ones as you. We just have a harder time getting them approved!)
We should run heads up at every race instead of 2-3 practice runs at every race. If you want to practice come a day early for the practice session. The bracket race on Sunday should remain the same. It makes the diversity of S/SS racers second to none.
AHFS should plot each engine family on a curve like we do in the sciences. This makes it a statistical method and not a punishment if someone is innovative. It hits at the heart of everyone's valid objection on this thread. The current method cannot address this.
Lynn A McCarty 3470 SS
Lynn A McCarty is offline   Reply With Quote
Old 04-03-2008, 05:34 PM   #4
Dick Butler
Lynn, Maybe with time Nhra will accept TOP/STK and TOP/SS and a couple wt breaks as Heads up at points meets as well as Opens Then people who like that will have a choice . Dick
Old 04-03-2008, 06:21 PM   #5
Evan Smith
Liked 115 Times in 5 Posts
Jim,
I also think a 2-3 tenth reduction of the indexes is a good answer. I think that is probably the direction that it will go, however, I would like more input, before trying to push something through. But those who I have spoken to so far seem to agree. On the other end of that, I'm sure the very small percentage of racers who are hovering on the current indexes can do some easy things that to find the same 2-3 tenths.
Evan
Evan Smith 1798 STK
Evan Smith is offline   Reply With Quote
Old 04-03-2008, 08:21 PM   #6
vic guilmino
Liked 56 Times in 21 Posts
ok put index to -.3
and go back to 1.00 under triggers
Vic Guilmino 1129 STK
Old 04-03-2008, 08:32 PM   #7
Jim Cimarolli
Liked 166 Times in 46 Posts
Smile Re: Automatic Horsepower Factoring System
I was around back in the '80's when NHRA added 2 tenths to all the indexes. One reason given by NHRA was because there were always about 4 or 5 racers at the bottom of the ladder that were struggling to be able to run the number and it would also lower the hurdle for new racers to get involved.
After about a year it was the same guys that were struggling to make it under again.
Jim Cimarolli is offline   Reply With Quote
Old 04-03-2008, 09:35 PM   #8
bsa633
Banned
actually i think it was in 93 they raised them...but i am with Jim B. give those .2 back + another one for starters.. .5 would work to even better in the long run! and have a group of individuals(not racers) to manually clear up the the ones that will be to far ahead,,
bsa633 is offline   Reply With Quote
Old 04-04-2008, 04:45 PM   #9
Lynn A McCarty
I was thinking that practice is boring. Bring what you brung and hope you brung enough. Heads up it in practice. If you dont want to, then use it as a practice run. Either way the fans will like it....oh..wait a minute...all the fans are at the NMCA heads up race!
50 lbs extra for an aftermarket block, 100lbs at least for aftermarket or replacement heads, 100lbs extra for bogus combos.
