Old 08-18-2021, 12:36 PM   #1
Liked 10,687 Times in 2,225 Posts
Default Re: Cleaning an aluminum head
I got some Dremel tool wire brushes the steel wire ones last longer than the brass ones. And have some ss steel tooth brushes to use in the runners with brakeclean.
Thanks for all the good ideas.
Common sense in abundance is genius!
Old 08-18-2021, 01:21 PM   #2
pmrphil
Liked 347 Times in 151 Posts
Carb clean will dissolve the carbon way better than the brake cleaner.
Phil Molski
PMR Performance
S/C 1623
Old 08-18-2021, 02:45 PM   #3
Jack Zimmerman
Liked 11 Times in 6 Posts
On my iron heads, bead blasting them in my blast cabinet with walnut shell media works pretty well in the exhaust ports and the other nooks and crannies, etc. as long as the heads are completely disassembled such that you can wash out all of the media with a garden hose and compressed air when you're done. And I've cleaned other aluminum parts with walnut shells as well and they don't change the surface finish at all so I'm guessing that they would work well and be OK on a cylinder head. But you should probably try it on a non-critical area first and start with a relatively low pressure. And if you are not aware, Harbor Freight has the walnut shell media if you need some.
Jack Zimmerman is offline   Reply With Quote
Old 08-18-2021, 03:29 PM   #4
I will shell out some dollars for some shells and some carb cleaner and give it a try.
We have black walnut trees in the yard and to crack the shells it takes a big hammer and safety glasses.
Old 08-18-2021, 08:35 PM   #5
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Talking Re: Cleaning an aluminum head
I just spit sweet tea outa my nose! Thanks Larry. Jim
Old 01-20-2025, 04:51 PM   #6
bpete
Liked 19 Times in 4 Posts
I know this is an older thread but...
Is bead blasting or soda blasting within the rules for stock?
It's not SAND blasting after all.
Brad
bpete is offline   Reply With Quote
Old 01-20-2025, 05:02 PM   #7
MAURICE BLENDHEIM
Liked 284 Times in 87 Posts
I blast them with Walnut Shells or Baking Soda. Just make sure there is no oil on them, Castrol Super Clean and a garden hose hooked to your hot water tank makes de-greasing easy before blasting. Lots of times you don?t have to blast after Super Clean is used with a brass wire brush. MB
MAURICE BLENDHEIM is offline   Reply With Quote
Old 01-21-2025, 02:06 PM   #8
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Originally Posted by bpete View Post
I Is bead blasting or soda blasting within the rules for stock?
That’s funny. I can tell you that the stocker guys having their aluminum heads ported ain’t concerted about the rules, much less what method is used to clean them.
Old 02-02-2025, 04:44 PM   #9
DonatoEng
Liked 8 Times in 5 Posts
I switched over a blast cabinet to Baking soda and its the best. Does a great job on carbs also then just wash i hot water and it all dissolves. You don't have to worry about any media hiding and coming loose and crashing an engine.
John Donato Stk / SS 3435
DonatoEng is offline   Reply With Quote
Old 02-03-2025, 10:07 AM   #10
Bob F
Liked 16 Times in 11 Posts
Soak in simple green works for me.
Bob F is offline   Reply With Quote
