Old 02-05-2022, 10:44 AM   #1
Rory McNeil
Default Re: Dime Rocket Fantasy
Originally Posted by Doug Hoven View Post
If you're running an 8 inch rear, you're out of luck if you wanted to run more than a 4.11 gear. For reference, the 6 cylinder nova currently has a 4.88 gear even with the 26 inch slicks I'm running.
I don`t know if they are still available, but 4.62 was a common ratio for the Ford 8". That said, the selection of ratios for the 8.8 is much better, but not nearly as good as the choices for a 9".
NHRA 6390 STK
M/S 85 Mustang
