Old 06-08-2022, 07:11 AM   #601
Liked 10,786 Times in 2,242 Posts
Default Re: Dumbo The Flying Elephant
I’m a nuts and bolts kind of guy. Patsy the IT person.
Old 06-24-2022, 07:38 PM   #602
I think we are done with the pink car. We have to get to work on Dumbo or he will miss Indy.
Old 06-25-2022, 07:27 AM   #603
tommy d
tommy d's Avatar
Liked 359 Times in 135 Posts
Half a second slower for some reason?
Old 06-25-2022, 01:26 PM   #604
Markeracer
Liked 67 Times in 28 Posts
Reason why it’s slower? One reason may be those slow runs could be used as the case for another HP reduction for that combo.
Markeracer is offline   Reply With Quote
Old 06-25-2022, 03:16 PM   #605
doglover44
doglover44's Avatar
Liked 491 Times in 229 Posts
Hope you get Dumbo going and figured out.
Jake Biermann
Old 06-26-2022, 07:11 AM   #606
I’m hope to be at the sports with Dumbo again. I have a lot to do.
Old 07-04-2022, 06:54 AM   #607
How did that happen? Both generators and the motor home are all due for service before we go back out. Race car is ready for engine oil and filter change and the transmission is ready for the same treatment.
Old 07-05-2022, 08:45 PM   #608
We have some grease fittings that won’t take grease, brake chamber that’s leaking, and a seal on the front diff that is leaking. We will have it back at the Cat House to finish repairs. I want my motor home to be able to pass a DOT over the road truck inspection.
Old 07-15-2022, 06:13 PM   #609
The above picture is using a stroke checker and a modified spring checker to find a out when each spring goes into coil bind. Install all hardware on the head, measure with a height mike, subtract valve lift, and add shims. Piece of cake.
Thanks Ken
Old 07-15-2022, 08:50 PM   #610
Frank Castros
Liked 2,740 Times in 967 Posts
Your new full time job keeps you very busy, praise the lord for your gift.
