Old 07-20-2022, 02:07 PM   #1
Liked 10,756 Times in 2,236 Posts
Default Re: Dumbo The Flying Elephant
Setting up to make custom shims for Dumbo, sometimes times I feel like the Dumbo.
Old 07-22-2022, 06:58 AM   #2
Today I should be able to assign springs to valves get them assembled and verify coil bind. It should be a busy day.
The reason for all the lathe work is the valve guide bosses have a healthy radius at the bottom where the spring cup or shim seat. Some of the shims I had to turn the OD down to fit the pockets or bore the ID to go over the guide boss.
ID:	64051   Click image for larger version
Old 07-24-2022, 02:30 PM   #3
Greg West
Liked 52 Times in 22 Posts
Amazing all the work involved to build a fast race engine. Every detail needs to be checked and double checked. Awesome work Larry.
Greg West is offline   Reply With Quote
Old 07-26-2022, 08:43 PM   #4
The worst thing about building you own race engine is I have no one to blame but myself. I wake up in the middle of the night and think of things I need to do or forgot to do the day before. It makes for a less than restful night.
Old 07-27-2022, 12:57 AM   #5
Mike Gray
Mike Gray's Avatar
Liked 691 Times in 199 Posts
Ibuprofen-PM especially after crawling in and out or under the car.
Mike 7570 A/SA
Old 07-28-2022, 06:38 PM   #6
After redoing my coil bind set up three times I'm confident that my numbers are correct and repeatable. I have one head ready to bolt on for final check for clearance from coil bind. The other head is clean with seals, valves, and ready for spring assignment with assembly. It took two sets of springs to get eight springs on the intakes to all be at the same open and seat pressure. The exhaust side springs are 10 pounds lighter on open and seat.
Does anyone have the old style Larson Systems Solid Height Gage, if so I think I would be willing to purchase it.
More later
Old 07-30-2022, 08:19 AM   #7
Has anyone noticed how the tolerance of parts seems to be expanded. I bought some stuff that was advertised to be .060" thick out of 32 parts no more than four were .060" thick. Thickness range was .064" - .056". Many of them would vary .003" across a face of 1.311". All was not lost with the unintended variations in thickness it allowed a closer set up than + or - .015'' shim choice.
............and so it goes
