Liked 10,759 Times in 2,236 Posts
The worst thing about building you own race engine is I have no one to blame but myself. I wake up in the middle of the night and think of things I need to do or forgot to do the day before. It makes for a less than restful night.
Liked 691 Times in 199 Posts
Ibuprofen-PM especially after crawling in and out or under the car.
Mike 7570 A/SA |
After redoing my coil bind set up three times I'm confident that my numbers are correct and repeatable. I have one head ready to bolt on for final check for clearance from coil bind. The other head is clean with seals, valves, and ready for spring assignment with assembly. It took two sets of springs to get eight springs on the intakes to all be at the same open and seat pressure. The exhaust side springs are 10 pounds lighter on open and seat.
Does anyone have the old style Larson Systems Solid Height Gage, if so I think I would be willing to purchase it. More later Last edited by Larry Hill; 07-29-2022 at 08:48 AM. |
Has anyone noticed how the tolerance of parts seems to be expanded. I bought some stuff that was advertised to be .060" thick out of 32 parts no more than four were .060" thick. Thickness range was .064" - .056". Many of them would vary .003" across a face of 1.311". All was not lost with the unintended variations in thickness it allowed a closer set up than + or - .015'' shim choice.
............and so it goes Last edited by Larry Hill; 07-30-2022 at 12:27 PM. |
After cleanup, put up, straighten up it will be rod and bearings day. I’m happy with how close I was able get the heads to my target. I just hope I have the correct target.
Checking for rod bolt stretch. .602 in the relaxed position. After .0055'' stretch to 6075''. After all the bolts I will check big end of rod. I think size is min. to max ID is only .0005.
Rods all checked good. Installed bearings and checked crank pin size and I had the desired vertical clearance inside the bearings. I have new oil rings and second ring to check in the bores tomorrow. Tonight I’m doing a little paperwork so I don’t lose my way or remind me of what not to do next time.
