Liked 192 Times in 83 Posts
Does anyone have any info on NHRA making head and necks restraints mandatory, effective immediately??.. inquiring minds wanna know..
Liked 333 Times in 180 Posts
Check 2023 rule book go look under each category ---YES some classes they are mandatory not sure where the speed or ET break is kind looks like about 750-800ET not sure on MPH ---BETTER check each category as they are listed ---also check for driving suits AND SHOE restriction too ---lotsa changes--FED 387
7.49 or quicker ---200 MPH or quicker ----OR unless class requirements require one---2023 NHRA rule book section 10.8 explains it fully--FED 387
Liked 883 Times in 237 Posts
Personally ,I was considering getting a neck restraint for a few years.
After seeing Will's crash at Cecil County I made my decision ,NHRA didn't need to mandate it for me. After talking with some Dirt Modified friends who have much more experience in crashes than we do ,I went with a Necks Gen restraint this year and am not bothered wearing it at all . It does take a little extra time to strap in and I opted to wear a balaclava in lieu of a neck collar but it's worth the extra safety. It really has not interfered with watching the other car either.
Since I wrecked my caviler at MIR. I have worn a head and neck restraint. I started in about 2006. I began using trevor ashlines safety solutions which has been bought by Simpson. I use the Simpson. Easy to put on on the restrain floats so there is no limit to turning your head to finish line race.
James Sessoms 2444 S/G |
Liked 64 Times in 25 Posts
I've been wearing them since '08 in both S/G and TS. I've had the HANS, Simpson Hybrid and the Necks Gen. I settled on the Necks Gen. Its compact and the channels are wide enough for the 3in belts, I also found it easier to get out of the car easier because it doesnt have the "backboard" like the HANS. I have decent side to side movement also. Just my .02. They are all good, just a matter of what you are comfortable with.
Carl Juliano TS 1275 John Juliano SG 151 Carl Sr. |
Liked 359 Times in 103 Posts
I have been using a Necksgen since 2013 when a friend died in a on track crash with a snapped neck.
All the head and neck restraints are much better than a neck collar which is really designed as a collar to protect from a fire. My question is the head and neck restraint with a 5 year sfi tag required to be re-certified if the restraint is not required by the class rules you participate in? I can not find a definite answer in the rule book. I have been told anything with a sfi tag must be re-certified once the tag runs out by a tech person with NHRA. I have also been told by a Division Tech Director if it is not required by the class it does not need re-certified. Most of the racers I talk to goes with it does not like the Division Tech Director. I just do not want be disqualified from a race due to a Head and Neck restraint sfi being expired which is not required for the class. I run SG and for safety reasons I use a Necksgen. Does a expired sfi need re-certified or not? How do we get a definite answer? Thanks Rick Cates Canyon TX. SG 5887 Last edited by 63corvette; 12-13-2022 at 12:13 PM. |
