Liked 288 Times in 109 Posts
I hear talk about racers installing an electric vacuum pump. It seems to me, doing so is a good idea because it will remove moisture from the crankcase without the engine running. In my specific situation, it would be used with Methanol as a moisture remover, not a power enhancer.
Are any of you doing this? Larry Woodfin |
Liked 109 Times in 38 Posts
I installed an electric vaccum pump on my Nostalgia Super Stock car. My main reason for doing this was to minimize oil leaks...and it worked well for that. Here is an article with some info on the pump.
https://grannys.tripod.com/evac.html My setup was much simpler, two hoses off the valve cover baffles, Moroso oil seperator, then to the vac pump.
Al Wilson NSS 7160 W201 stock |
Thank you, I appreciate the information.
#4 | |
Liked 105 Times in 26 Posts
Shaun, no, I have not done so yet, but I do think it is worth considering.
