Old 10-11-2023, 10:27 AM   #1
HP HUNTER
Liked 372 Times in 129 Posts
Default Re: 1979 C-10 Shop/Race Truck Build
Originally Posted by Kirk Morgan View Post
Are you doing dyno work in Texas? Little River has a lot of history.
Yes-we dyno test.
Old 10-11-2023, 10:37 AM   #2
HP HUNTER
So I started my 350 build, .060 over 2 bolt 010 block, I did some work to the factory cast crank which ended up @ 3.483 stroke, I put a 6 inch rod in there with a + 6 cc dome Mahle piston, my Fuelie heads came in at 74 CCs which gave 10.8 compression. My solid lifter cam was .528 lift @ the valve with 264 @ .050 duration on both sides, 108 lobe separation. I used a Performer RPM intake with a 750 Holley, the Moroso pan was modified.
Old 10-11-2023, 07:37 PM   #3
HP HUNTER
A picture of my new 350
Old 10-11-2023, 11:10 PM   #4
HP HUNTER
The 350 with 4 passes delivered the following performance in street trim with the power steering and steel two piece drive shaft @ 3970.
1.50 60 foot
7.04 660 @ 94.2 MPH
https://youtube.com/shorts/aS_Mx_tTz...4QheGAyGXu5mMu
More to come.............
Old 10-14-2023, 06:19 PM   #5
Woodfin
Liked 286 Times in 108 Posts
Which track is the video?
Old 10-15-2023, 09:30 AM   #6
Liked 10,745 Times in 2,235 Posts
You truck looked and sounded very good on the track. Congratulations
Old 10-16-2023, 09:33 AM   #7
HP HUNTER
Thanks, I should have bought your truck, as I've destroyed the factory leaf springs, pinion angle will not stay in place.
Old 10-16-2023, 09:36 AM   #8
HP HUNTER
Concrete Palace Xtreme
Old 10-16-2023, 03:23 PM   #9
The "Private Lee" 71 440 /375 hp would twist the axle so bad the paint would pop off the tubes. We had Cal-Tracs and the springs were fine put the pinion angel would change a lot.
