Liked 1,310 Times in 359 Posts
Dawson Pauley #2827 N/SA 1980 Malibu SW 2S 305/180 #2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide |
Liked 8,210 Times in 1,536 Posts
OK, I have a lot of advice for you…haha…..throw the self adjusters in the garbage, You need to invest in NEW brake spring kits for the rear….AND it won’t BRAKE ( pun intended) the bank…With your hood clearance you can run a much TALLER K and N air filter…Proud of you man, you are making progress !!! More TIPs to come……..
You know, it’s sooo nice to see a youngster with some fire in his BELLY actually put his $$ where his mouth is AS opposed to the GEEZERS on this site that flat WEAR out Billy Nees and YAC week in and week out KNOWING damn well that most of them are just DREAMING….Build it AND they will come ….
I did not know until he put this thread up who this young man was, let me just say this boy has talent. He has already won a national event in super gas , and comes from an excellent racing family with a father, who is also a champion. I am sure he will find success in this class also.
good luck my friend.
#5 | |
Liked 110 Times in 29 Posts
I agree with MJ on the air cleaner element. You probably have the hood clearance to use a 4 inch especially with a dropped base such as the Speedway Motors # 91011062-2 . A lot of racers use this one without any element as it has shown ET improvement in many cases. And it's only $23. Remember that most elements are restrictive and will require a jetting adjustment for optimum performance. As a side note, I'm a wagon guy and love yours. Wishing you the best.
#7 | |
Dawson Pauley #2827 N/SA 1980 Malibu SW 2S 305/180 #2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide Last edited by JP1738; 02-20-2024 at 09:29 AM. |
#8 | |
Liked 84 Times in 21 Posts
No it isn't. With no air cleaner gasket the top of it is flush with the choke housing which is legal. I would run a thin gasket as I don't want metal to metal contact. Gaskets range from .044 to .130. I don't think NHRA would mind if it's .044 above. I do think they may say something if you used a .250 or more spacer that's available. With that being said, I did see a National event winning car whose base wasn't even close to the choke housing. It looked like a mini velocity stack. Really surprised NHRA allowed it. Wasn't a Q-Jet carb though.
Liked 869 Times in 165 Posts
Glad to see another "kid" like me learning his ways in Stock Eliminator. You definitely picked a good combo to learn with. Tidbit of info on distributors. I ran into the issue of not wanting to buy an expensive new distributor, but didn't want to buy a cheapo chinesium distributor either. Some late 80s/early 90s EFI GM products have small cap, divorced coil HEI distributors that have a 2 wire magnetic pickup that works with MSD boxes, and have locked out timing from the factory.
1189 F/SA Defunzalo Racing Enterprises |
