#61 |
Liked 398 Times in 157 Posts
In other news....I ordered the adjustable upper rear control arms and the grill that goes in the hood scoop from LMR. I checked the pinion angle and it's around 3-4* down, but this will let me adjust for what works best.
I think I'll have to get a decal made that says "I've never spent so much to go so slow" !! LOL!!! |
#62 | |
Liked 369 Times in 199 Posts
In 1994 I tried w/ the stock gas tank, my system is single point injector EFI, fuel ran from in tank pump w/sock, to TBI hat, to injector top inlet screen/pinter, then to attached regulator, then a quarter inch return line to the tank. By disconnecting up front lines from Throttle Body, creating and inserting a "temp U-Line connection, plugging into the diag. Port for the ECM to add a switch to temp override the ECM 10 sec key on prime feature for the fuel pump I could both take samples, and could also just circulate the fuel through the system, or drain the tank/lines completely from under hood area. 1994 First Divisional race of the year, drive in on pump gas, drained the tank and lines completely of the pump gas I drove the car in on then added 2-3 gals of VP C-12 race gas and went for pre-race fuel ck....And failed the ck, oxygenation additives put the ck out of whack (to this day, and I drove the car all over the country in 1995. Then 96, and 97, to many, many events on pump gas, after properly being shown how to wash the system to remove the oxygenation additives, the only fuel ck I ever failed was that 1st 1). A great NHRA Div. 7 man taught me how. Drain the tank and lines fully. Then get a single gallon or 2 of red diesel, add the diesel to the tank or cell, bounce the rear of the car to splash that as high on tank or cell sides as you can, then you need to cycle flush all your lines for 10-20 mins circulating the red diesel through the lines to wash them, and do not allow the diesel to enter carbs, throttle bodies, etc. Drain the tank and lines again fully, then add 2 gals of race gas to the tank and wash 10 mins again (circulating that new race gas to wash the system of diesel, and drain again...save the diesel and that now dirty race gas, both can be used for future washes). Now add 2 gals of clean new race gas, rehook the system back up, check for leaks, and head for a fuel pre-ck. You will have burned up an hr. to an hr/1/2 of time, and will pass the ck....after the event I simply drained and sold the race gas left, or carried it on to next event. Add back the orig. Pump gas and fire it up. (But, once you do, the wash of the system will be necessary again). I drove track to track all over in 1995 doing that, a huge pain in the rear, but it is doable. But, since my engine rebuild, adding a 5 gal. Cell, removing the tank, pump gas has not been introduced to the system period as race gas is no longer $7.00 a gal., and diesel is getting nowhere near those new Ross pistons or Sealed Pro ringsets. If it has pump gas in it now, my suggestion is do the first wash at home, then add race gas, then get a pre-ck before your 1st Q1 round (with plenty of time to wash it again if necessary, and come pre-prepared!) Also bring a fresh set of plugs pre-gapped to throw in it. Good luck brother.
Gary Lucier - 7832 STK. / 7832 E.T. EF/S Slow Sled. I am, but a simple test of your true patience. So, do all the really "Big Wheelies" you can! |
#63 |
Really sry about the book above, but I was screwed in 1994 as 1). I did not know the answers. 2). Fuel ck was open a day before. 3). That tech guy was great, knew how to resolve my issue, sold me a brand new 2.5 gal fuel container out of his own truck, then called & arranged a Las Vegas track maintenance employee to secure and sell me for cash 2 gallons of red diesel out of a temp lighting unit on the property, then stay with me teaching me the system wash procedure until I passed. Luckily there was time the day before Q1 to complete it.
Today, you are not even assured that the scale will be manned, ckd., and accurate or fuel ck will be open after pitting. And Q1 comes early in the AM. |
#64 |
Concerning switching to race gas for fuel check, on my 85 Mustang Stocker, I retained the factory steel gas tank, and for running non LODRS or National events, I would run Chevron mid grade pump gas, which was usually 3 to 4 hundreths quicker than C12 in my low compression, carbed 302, mainly because in Canada, VP C12 was over 20 bucks a gallon. Before getting ready to enter a NHRA Divisional or National event, I would run the fuel pump with the line to the carb running into a fuel jug, until it stopped pumping, then I would add a couple of gallons of C12, and pump that out, then leave the gas cap off, to "air out" for at least an hour, then add more fresh C12, and then load the car up for the trip to the track. Maybe I was just lucky, but I never failed fuel check doing this method.Your results may vary.
#65 |
One step ahead.....numerous back....
Had an accelerator pump weeping a bit, so I replaced it. Hit the key and won't fire? Checked, yup lots of gas...no spark??? After a bit of wire tracing and pulling the msd box out I found a momentary switch under the dash went bad! I had installed it 30 years or so ago when I was running the 302 with 2 4bbls and had the distributor locked out at 38*. I would hold in the button to get it rolling over then let it out to fire it up. Apparently it decided that it didn't want to play any more. Better here than the track of course. Totally forgot it was there! lol. Installed a neutral switch. Found a pair of red seats...buddy wants $350 for the pair. Still looking.... Wrote off the wifes bronco Tore my left bicep muscle off working out so that laid me up a bit. First race is 24 May.....getting concerned. It might be a bracket car until I get the rest of the stocker stuff finished...
Jim Miller 103 U/SA |
#66 |
Liked 706 Times in 283 Posts
We run a second tank with nitrous fuel. If u have 2 tanks, 1 pump and 1 race gas. Then only thing to clean is lines going forward.
#67 | |
I can just imagine the look, hey what is that other tank over there...Answer, oh. That is our nitrous (or pump gas), fuel tank. Lol. And the fine tooth comb search for associated lines, selenoids, etc.
#68 | |
#69 | |
#70 |
Sooooo.....
1) Got my springs/retainers/locks, but my lifters still haven't come in. 2) Tried to put on collectors and the four sets of heeaders I have, the ones installed have an odd ball size collector flange. 3) bought new plugs but even though the machine shows them for a 79-93 mustang...they're the wrong ones. I even thought to run them but after sticking them in a head and looking in the chamber? Umm, nope can't use them. 4) Got the car painted...it's very apparent I'm a mechanic and not a painter! LOL! I think I should of painted it orange there's so much peel! 5) I'm buying slicks from a local Stocker guy and tried to get tubes...nope, a month out. I have a partial solution, we'll see... 6) I haven't pulled the engine to confirm 24 or 26 spline converter (Put it in, in 1993 and don't remember what I ordered, I just know it's a truck, pan fill c4) so until then, I'll be running the 2800 stall bracket converter. So it looks like I'll be going to a bracket race this weekend with wrong cam/heads/intake/converter, no collectors......this will be a "first time since 1997 it's been on the track" so I have zero expectations, just get it on the track. Make a few passes and look for bugs to work out. Here's some pic's of the mess.
Jim Miller 103 U/SA Last edited by goinbroke2; 05-22-2024 at 04:51 PM. |
