#11 |
Liked 1,226 Times in 343 Posts
Got the governor out of the car last night, it currently has a #2 weight along with another that is not stamped with any marking. Had an orange spring on the #2 and a green spring on the unmarked weight. See images.
Dawson Pauley #2827 N/SA 1980 Malibu SW 2S 305/180 #2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide |
#12 |
Liked 133 Times in 76 Posts
Just me but I would have obtained a couple of governors to experiment with and left that one alone and tag it with it's shift points.
Someone asked about a burnout with the auto shift. When I ran a T350 I never came out of a burnout in 2nd as that shocks the weak link in a T350, the intermediate overrun sprag on the direct drum. |
#13 |
In your case, I'd probably put a full , unmodified weight in there to match the other one, and try that first.
#14 |
Liked 9 Times in 4 Posts
Maybe this will help, according to my B&M instruction sheet the weights go from 1 to 6. 1 being the heaviest 6 being the lightest. the springs go purple blue green yellow orange red in that order. purple is the stiffest spring and red is the lightest.
First gear late shift excessively light spring on weight. High gear to soon excessively heavy weight. the plain steel unmarked spring looks like a stock factory weight. Dan |
#15 | |
#16 |
I tried to last night but the file format of my laptop or whatever is to large to upload to this site. The instruction don't go into much more detail other than if it shifts to early go to lighter weights and/or springs if it shifts to late go to heavier weights and or springs. The stock weights and springs on the governor will shift around 4200-4300 rpm this was a safety factor is if the unaware driver left the shift lever in 1st or low it would automatically fail safe shift before the redline of the stock engine so they didn't have loads of warranty replacement engines. Shift kits were developed to bypass this safety so you could hold any gear till you manually moved the lever . I tried weighing a few spare weighs I have from my kit to give you an idea of what they are put my 14 year old grams scale is DOA .
#17 |
I would try the yellow spring with the #2 weight and leave the other alone. then test if to low try orange spring.
#18 |
Liked 20 Times in 14 Posts
Number 1 weight and a purple spring! Should get you down about 600 rpm. Looks like one of springs is green. Change it with a purple and if you need more change the other spring if you can tell what color it is. According to chart the heavier weight will change shift approx 400 rpm Springs move approx 100 per color up to 600 total. There are 6 colors in the kits.
#19 |
Liked 754 Times in 213 Posts
This may help you also with the B&M chart...
https://www.jegs.com/InstallationIns.../130-20248.pdf Last edited by Charles Stewart; 04-13-2024 at 10:06 AM. Reason: add info |
