02-10-2023, 12:00 AM | #11 |
Liked 943 Times in 260 Posts
Re: Fuel line, what's the best?
Same here, my bracket car has the same Moroso aluminum fuel tubing that I installed 35 years ago, never had an issue with it. Important to have it secured properly, I have rubber lined mounting Adel clamps every 10-12 inches.
04-21-2024, 04:32 PM | #12 |
Liked 154 Times in 58 Posts
Anyone ever try the Russel twist lok rubber hose? https://www.summitracing.com/parts/rus-634163
J.T. Rose & Associates U/SA 302R |
04-22-2024, 10:22 AM | #13 |
Liked 424 Times in 204 Posts
I just replaced SS braided line that was in service for 20 years without issue. I’m now using black nylon braided Lines.
04-22-2024, 11:08 AM | #14 |
Liked 703 Times in 206 Posts
I've gone to PTFE lined braided hose for all fuel lines and transmission lines.
It will outlast any rubber type hose and will generally handle higher pressures and temps than typical rubber type braided hose. I particularly like it for injection systems that are running 50 -90 psi.
04-22-2024, 11:32 AM | #15 |
04-23-2024, 01:20 PM | #16 | |
Liked 4 Times in 3 Posts
04-23-2024, 04:54 PM | #17 |
Liked 50 Times in 24 Posts
What do you use for the transition fittings to go from aluminum line to braided or to system devices? Does the connection seal by means of a furrell, a flare, a swagelok, or something else?
