Liked 373 Times in 129 Posts
Liked 880 Times in 311 Posts
Mark,
since I'm not well informed about the stocker combinatons... What year and body does the 335 HP 396 fit? I found the small cam 1969 335 HP 427 in Dwights class tool section
Adger Smith (Former SS) Last edited by Adger Smith; 05-20-2024 at 12:35 PM. Reason: add |
I believe its been factored down to 330 HP with an automatic, 1968 Nova, Camaro, Chevelle SS From GM 350 HP 396 .460/.480 lift. 335 HP 427 is .398 lift I believe.
OK, Mark...that works.
I was looking for a GM rating of 335..& should have looked at 350 HP specs. Yes, 335 is the rating for the 1968 350 HP 396 with stick shift. What I think I saw is all bodies with stick in 1968 for stock are 335. (Base) I see it has the bigger cam, too. That Dog might hunt with a stick. Thanks for the info... Adger
Adger Smith (Former SS) |
#5 | |
Liked 327 Times in 121 Posts
I'm guessing you didn't flow with the manifold on.
![]() You would be correct, I simply wanted a base line on the heads as they were run. The 396 was a 440 HP engine as run, I know the factory intake easily supports more than that from other builds I've done in the past. I would be interested in knowing what a worked over intake was worth? I'am pretty sure the heads can be very much improved on, we're going to see soon. https://classracer.com/classforum/sh...ad.php?t=78477 Last edited by HP HUNTER; 05-21-2024 at 12:39 AM. |
Here's a better picture of the head before work was started. Notice both valves are sunk quite a bit. I checked all the valve heights, and checked PV clearance, CC the chamber 100.5. So according to my calculations its short on compression.
Seats installed.
Done and ready to dyno.
