#1 | |
Liked 90 Times in 27 Posts
William Kilduff 1970 Barracuda (still trailer jail, indefinitely?) 1968 Camaro SS/C |
Thanks. I've heard about this recently, but don't know anything about them. I'll be googling it tonight.. Haven't been able to make time for the truck recently. Tomorrow is looking good for me getting time to get back on it. Going to check out the speed sensor on the case that missed earlier on.
#4 | |
Why was it rebuilt to begin with? Those are pretty reliable, I don't seem to have too much trouble with them. But then they get the Sonnax fixes, the Alto frictions, and a Superior valve body kit. That tends to eliminate further problems. Order yourself the ATSG manual for the 4L80E. If you're going to work on it, you'll find that to be indispensable.
Alan Roehrich 212A G/S |
#5 | |
Liked 708 Times in 285 Posts
Input speed sensor sounds very promising
A stand alone TCU is a waste. There's no reason to need one or go through the hassle.The stock stuff works fine, there's several million dollars worth of R&D behind them for reliability. Adding some stand alone controller requires more wiring harness and adapting/interfacing that just adds complexity, and does not guarantee a solution.
It's more likely to be a wiring harness problem than an ECU. The wiring diagram for your truck can be found online, probably for free. There are two ATSG manuals that are good for that transmission, one is a dedicated rebuild manual, the other is a manual that covers it and the 4L60E, and includes the electronic/electrical diagnosis.
Liked 43 Times in 29 Posts
i was a GM service manager for many years, when we would see problems like this we usually found that the pin tension on the harness was not adequate for a proper connection. It is very important that you probe the terminals with the proper pin connectors, if someone used a test light or an ohm meter to check for continuity than they may have spread the terminals just enough to make for a poor connection. Make sure your shop has the proper tools to diagnosis this concern.
Mark Ruset 2048 STK |
#9 | |
I'll certainly keep this in mind. Thanks.
