Old 06-13-2024, 03:47 PM   #25
Cglrcng
Cglrcng's Avatar
Liked 430 Times in 214 Posts
Default Re: Dumbo The Flying Elephant
In trying to make more power I know we need to raise the RPM level. To me that means paying attention to fits. Well I found this one by accident. The gears that go on the crank that drives the camshaft are black in color and have an ID that has been bored. Two out of the three gears still had portions of the ID still black in color and fit looser on the crank. I do have one that cleaned up on the ID and is a good sliding fit on the crankshaft. I don't know if that could be a potential problem at 150 Hertz, but just trying to keep everything straight and round.
I don't actually know the legal answer to the question (but it may be worth the asking of the proper tech person), but...can you legally overbore the ID and press fit a brass bushing to correct the ID of the hole for correct centering and true up of those cam/crank gear sets?
Gary Lucier - 7832 STK. / 7832 E.T. EF/S Slow Sled. I am, but a simple test of your true patience. So, do all the really "Big Wheelies" you can!
Cglrcng is offline   Reply With Quote
