Old 07-19-2024, 11:21 AM   #1
Frank Castros
Liked 2,680 Times in 951 Posts
Default Re: Dumbo The Flying Elephant
Larry,
I hope you make it to Bowling Green for Doug's Test Session.
Frank
Old 07-19-2024, 11:32 AM   #2
Liked 10,681 Times in 2,222 Posts
Just spent $1,000 plus on two sets of springs and two sets of main bearings.
I must be crazy.
Old 07-19-2024, 12:56 PM   #3
pmrphil
Liked 346 Times in 150 Posts
Welcome to the club, Larry.
I thought you were already a lifetime member
Phil Molski
PMR Performance
S/C 1623
Old 07-20-2024, 07:10 PM   #4
It was a good decision that I ordered two sets of main bearings because one set was damaged in shipping. The package was mishandled so bad it broke all the air bags that were to cushion the parts in transit. In defense of the seller the parts were direct ship from the manufacturer. Clearance on the mains is good on one and rest need to be adjusted a small amount. Top to bottom I had a good day racing.
Old 07-22-2024, 07:23 AM   #5
Getting old always makes you look for the easier pathway. My block has five main caps with 26 fasteners with a three step torque sequence on 16 of them. So I decided to take a shortcut and skip the last step and check clearance. It was in no way predictable and off a mile. I finished the last step and everything was as it should be. I knew better.
Old 07-22-2024, 12:12 PM   #6
I am disappointed in making this post.
I've been on hold on customer service for two hours and in that time I have went from 34th in ?Q? to 22 in two hours. Buckeye sales needs to have better customer service and support.
Old 07-23-2024, 07:36 AM   #7
Default Re: Dumbo The Flying Elephanta
In mixing and matching the bearing shells the SOT (Stupid Oldman Trick) bit me in the butt. Old folks should not try to do any work in their head, there is no room, it is full of useless information. Long story short I put the wrong shells in the caps and the clearances were way off. After disassembling I miked the shells and replaced thick ones with thinner ones and everything looks like it might work. We will know on dyno day.
Thanks Mr JR and Mr Byrd
