Old 01-15-2025, 06:23 PM   #1
Ed McLawhorn Jr.
Liked 19 Times in 17 Posts
Default Small runner intake gaskets
Need recommendations for sbc small port intake gaskets. Specifically for 520 super stock port. I was using Mr. Gasket 100's and cutting for fit. No issues until they seem to be out of stock or discontinued. I can buy gasket material and cut one out, but was hoping for something close and minimize cut to fit. Thanks.
Ed
Ed McLawhorn Jr. is offline   Reply With Quote
Old 01-15-2025, 08:25 PM   #2
Liked 1,874 Times in 422 Posts
Default Re: Small runner intake gaskets
FelPro once had a huge selection of small block Chevy intake gaskets.
Old 01-15-2025, 09:28 PM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Take a look at the SCE catalog. they have many different size and port shape SBC intake gaskets. plus their material is far better than the old MR Gasket material.
Old 01-15-2025, 10:27 PM   #4
Bob Gullett
Bob Gullett's Avatar
Liked 510 Times in 117 Posts
Ed
If you need a 1/8” gasket the 1245 felpro is a small port.
68 Chevy11 327 F/S
Bob Gullett is offline   Reply With Quote
Old 01-16-2025, 01:02 AM   #5
prostockpete1
Liked 90 Times in 52 Posts
Mr. Gasket offers sheets of intake gasket material ... Holley / Mr . gasket site shows # 77B & 77C part # .s
prostockpete1 is offline   Reply With Quote
Old 01-16-2025, 12:22 PM   #6
Ed McLawhorn Jr.
Default Re: Small port intake gaskets
Thanks everyone. I?m looking at some sce gaskets. Not sure if they will fit the bill, time will tell. Worse case, I will buy gasket sheet and cut to fit. Hoping there was another option.
Old 01-16-2025, 02:28 PM   #7
Dirk Olson
Liked 172 Times in 46 Posts
Send a gasket that you have fitted to your head to Cometic and they will reproduce that gasket with your P/N on it.
Ed I talked to Lance Line this past weekend and he said that you give him call he should have what you need at Line Performance in Wright Minn.
Dirk
Dirk Olson 5036 STK
Dirk Olson is offline   Reply With Quote
Old 01-16-2025, 03:31 PM   #8
Ed McLawhorn Jr.
Dirk
Thanks Dirk. I had a friend call this afternoon and suggested same thing. That?s what he ended up doing.
Old 01-18-2025, 09:21 PM   #9
shoebox racer
shoebox racer's Avatar
Liked 2 Times in 2 Posts
I might have something for you, I sent a private message with my phone number.
Mike Parmenter
shoebox racer is offline   Reply With Quote
Old 01-24-2025, 09:51 AM   #10
Kevin Panzino
Kevin Panzino's Avatar
Liked 753 Times in 139 Posts
Ditto on cometic cutting a gasket for you with your own part number.
Matches perfectly if you do your homework and send either a detailed cad drawing or a perfect template.
However, unless anything has changed I wasn?t at all happy with the gasket material they use. It?s quite hard and doesn?t compress very well. Given that there is normally a slight variation in the angle between head and manifold no matter how careful you are with your angle mill calcs, measurements and execution you can wind up with coolant weepers down into the galley you won?t see. Plenty or rtv around the coolant passages is a must!
Kp
