Old 02-20-2025, 08:52 AM   #8
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
Default Re: How to Modify Stock '72 GM A body A Arms for more Travel
Your car will have excess positive caster as your upper an arm will be moving up and out, so will need to be shimmed accordingly. I believe the toe in will also change then as the tires will pidgeon toe in needing correction.
I actually had to make limiters as my suspension travel was about 6.5?
chris ok is offline   Reply With Quote
