Old 07-25-2025, 10:10 AM   #1
SDmopar
Liked 207 Times in 49 Posts
Default Eliminate AHFS
It seems as the majority of us here want to keep the sovereignty of Class racing alive. If the Automatic system was cancelled how could the Sanctioning bodies rate evaluate HP ratings? It seems that the majority hate the bogus combos and ratings on new combinations. Everyone wants to be able to run wide open without penalties. People also have combos that have been murdered and are no longer competitive. Personally I like a system that looks at the data. It?s the most unbiased constant way that requires the least amount of energy for the sanctioning body. I feel the real hole in the current system is it only corrects the softer combos or penalizes the players that make there stuff fast. I could be convinced that if the top 3 cars in each combo can go -1.30 they should get hp. I also believe if the 3 fastest cars in a combo can?t go -1 under they should get a reduction. When the fastest meet in class it?s obvious who has the hp rating advantage.
Throw up some ideas. But keep in mind there is a car coming to play that everyone is concerned with it?s ratings. How do you balance the new bogus numbers with the combos that got crushed early because someone thought they needed HP.
Brian Anderson
5058 B/SA 99 Chevy Camaro SS
SDmopar is offline   Reply With Quote
