#161 |
Liked 404 Times in 158 Posts
Got a call this morning, tranny shop got some more info and is proceeding. Asked the hp, lol...I said 200 or so, maybe a bit more so build it to hold 400hp. He said no problem, they are on it.
Now just waiting for them to get it done....
Jim Miller 103 U/SA |
#162 |
Transmission is done, in and running good. Now to replace the brand new temp gauge that crapped out and might be ready for this weekend.....we'll see, still 2 more days for potential carnage, lol.
#163 |
Liked 5,134 Times in 1,958 Posts
What was wrong with the trans when the "experts" took it apart?
"We are lucky we don't get as much Government as we pay for." Will Rogers Last edited by Mark Yacavone; 07-03-2025 at 12:58 PM. |
#164 |
Said it sat it water at some point and gungy inside and the linings came off, etc. At that point I was "just fix it", lol.
#165 |
Well, I got to the track finally! Friday morning, got to the track, went for a cruise around the pits to warm it up and see smoke...melted the oil line going to the pressure gauge on the header. Fixed that and went for a test drive...broke the shift gate I made on the lathe so now it goes from 1-neutral. Well, I'll just leave it in drive and let the shift kit determine the shift points so I don't accidently hit neutral.
So, new converter, transmission, driveshaft, 5.14 gears, adj upper control arms, last years best pass was a 15.55 on my 14.85 index. Can't wait to see how much quicker it is!! Friday First pass shifting itself 15.42@83.55.......ummm, what??? Second pass, shifting myself and hitting neutral 17.22@72.52 Third pass, shifting myself by ear, hearing it nose over at 5000rpm or so 15.48@83.33 Fourth pass, shifting by the shift light 15.00@86.39 but it is laboring above 5000 Sat morning decided to check timing with my light I previously said was messed up and was supposed to replace. 99.5* ok, so that's done. I bumped the distributor back 5* or so. First pass 14.85@86.96!! WHOOOHOOO!!! Bumped the timing back another few degrees Second pass 14.70@88.35 but the alternator belt broke. Paid $20 for the gamblers race just to get another pass, charged the battery up and first round my .078 light to his .094 had me enough ahead I was hard on the brakes to win with a 14.87@75.68! Second round, sat in lanes for a bit, hit the key to go and...dead batt! Bad way to lose but whatever, there to test and tune more than race anyway. Sunday morning, good and charged, got up first in line so engine was around 140* staging First pass 14.68@87.99 Second pass (qual on a 14.70 dial) 14.72@87.67 with a .074 light Was going to charge/line up first round, etc but realized even if I did win a round or two, there would be a point I couldn't reach the turn around time between rounds so decided to pack it up. Good thing as it wouldn't start to load, then the genny wouldn't start to charge the car so I could load, lol! Anyway, got home with another list of "to do's" so I'll get on that next. For brevity I left out a lot of gremlins that occurred, like breaking the hood release handle, LOL!! Bottom line... -.17 UNDER THE INDEX!!!!!
Jim Miller 103 U/SA Last edited by goinbroke2; 07-07-2025 at 11:39 AM. |
#166 |
I have eye surgery Monday AM so everything will be on hold for a bit, however....
Just received a new electric water pump, picked up a new fan belt, bought a new timing light and have the following "to do" after this weekend. 1) Shifter, mill and install a new shift gate 2) Replace fan belt 3) check rear axle vent to see if plugged 4) Repair/replace headers as one collector flange cracked 1/2 way 5) Hook up second fan on rad 6) Swap bolts around in the bellhousing (found one tight from being bottomed out, couldn't see it from below). 7) check/adjust timing as well as limit total mechanical advance 8) Find clunk in upper right control arm (just noticed) Between the arm and body, not housing. Rocking in park has a clunk so either upper hole is elongated or something bad is happening to the new adjustable arm or I need to install battle boxes to secure the upper mount points. Either way....something! 9) get new lettering for windows. I gave the guy dimensions 3" x 1" as per the rule book and he gave me 1" tall by 3" long "U/SA" and "103" lettering. At some point need to replace the front tires/rims with front skinnies as well as 4cyl springs and 90/10 shocks. Never ends does it.....LOL!
#167 |
OK, I waited 7 days with parts IN THE GARAGE but I couldn't touch them because of my eye surgery...Went out to see if I could do anything small/light/not too straining.
Installed the plug wires and found one of the connectors on the cap is loose/wiggling and didn't like it so installed the original cap/rotor with the new wires. That was easy enough so... Got the electric water pump installed and found the bottom pulley won't fit because it interferes. So, cut down the double pulley on the lathe (only use the small pulley anyway) and got that installed. Then I noticed I don't need the coolant pipe coming out of the intake so I got a plug for that and installed it. Now I have to look where to mount the alternator since it's supposed to mount where the electric water pump is now, lol. Wife called, time for the hottub so that's it for today, tomorrow I'll get back at it.
#168 |
Got the alternator bracket fabbed up and installed after 4 days and 5 attempts...just didn't like the look/stability of it.
1) Fan belt installed with a brand new in the box 60amp alternator I found upstairs in the garage I bought for another project. (forgot I had it, can't remember what I got it for, everything else is charging...hmmm) 2) Milled a new shifter gate (forward pattern) and installed that 3) Pulled the cracked header off and fabbed up a new flange, got that all welded up and reinstalled. 4) cut the collectors down to 18" Still not sure of the length required, maybe I'll paint a stripe down them and see where it burns off? 5) Fixed the too long bellhousing bolt, wrong hole (that's what she said) Noticed a slight leak started from the 35 year old flex lines going to the tranny cooler, add that to the list. Did my pre-op today for my second eye, surgery for that one is 25 Aug so it's not looking good to get back out this year. crap. Two years in a row I got out at the first of the season for one weekend and then due to life couldn't get a second weekend in. Still trying, we'll see. More to do, picking away at it when I can.
#169 |
Here's a pic of the alternator set up now. Once I have time I'll probably go back and replace the aluminum flat bar with a new prettier one with only one hole, this was a piece of scrap aluminum from the kids junior that's been gone for 6-7 years. (Why I never throw anything away, LOL!!)
Alternator is nice and low now, belts tight, charging great. Once I get to the track I'll find out if high rpm kicks the belt, lol.
Jim Miller 103 U/SA Last edited by goinbroke2; 08-13-2025 at 04:32 PM. |
#170 |
Wife told me Friday at 10am her plans she had for us on the weekend fell through. I said..well....there's a race this weekend...and she said yes?!?!
Loaded up, took off to the track for a bracket racing weekend. (more testing than anything to be honest) I was in the last pair to go down the track Friday night. Last pass I ran back in July was a 14.68@87.99 on my 14.85 index. First pass Friday night was 14.68@88.99mph -.17 under Pulled the booster cluster out of the carb and cleaned the one air bleed that seemed to be plugged, engine sounded cleaner and... First pass this morning was a 14.57@89.19 -.280 under!! Things are going in the right direction!! Next pass, did my burn out and pulled to the line and they shut me off, tranny leak. Must be one of the rubber lines going to the cooler blew off or broke, whatever, I can fix that. Looked....uh oh...the fluid is coming out of the bellhousing!! CRAP!! Towed it back to the bus and then fired it up and drove it in, made a bit of a mess but whatever. So...drive home a couple hours, pull the tranny and change the front seal, or, jump in the 86 mustang and bring it back and just bracket race that, or...take the wife to the drive-in, in my 86 mustang, guess which one she chose for me? LOL! Just like that, the new converter and new transmission pooped the bed. I had 3/16 to 1/4" movement in the converter when I pulled it up to the flex plate so it wasn't bottomed out in the pump so I don't know what happened. Eye surgery Monday so this might be sitting for a bit. Going in the right direction, but man, it's going SLOWWWWWLY!
