Old 08-06-2008, 06:39 PM   #1
340Cuda
Liked 805 Times in 341 Posts
Default Re: msd ignition
Originally Posted by Johnny U View Post
A friend of mine has a new dragster and he has been fighting a top end miss/flutter all year. He has tried different carb jettings and different carbs to no avail. Question is has anybody had to lengthen the msd trigger wires beyond the six foot length that they give you. He thinks that this may be where his problem is as there is not much room in this dragster and the msd box is approx 12 feet away from the engine. Have anybody run into this concern.Thanks .
After we went to an MSD many years ago, our car will miss if the distributor cap is not vented well.
Bill
Old 08-07-2008, 01:32 AM   #2
Jeff Beckman
Jeff Beckman's Avatar
Send a message via AIM to Jeff Beckman
I have gone to this extent, shield from the crank trigger to the msd box. Run a ground wire soldered to the shield to a chassis ground. On the crank trigger pick up, use a screw clamp to secure shielding to the crank trigger pick up nut.
Jeff Beckman 318J ET, SG
318T SC
Jeff Beckman is offline   Reply With Quote
Old 08-07-2008, 12:44 PM   #3
SC1448
Liked 2 Times in 2 Posts
Cool Re: msd ignition
Try disconnecting the Tachometer (green wire) and see if that helps. Been there, done that.
-Don
SC1448 is offline   Reply With Quote
Old 08-07-2008, 02:34 PM   #4
Johnny U
Smile Re: msd ignition
No Mike, he has not fixed the problem yet but he ordered the shielded cable and is going to try that first. Thanks for the many replies.
Johnny U is offline   Reply With Quote
Old 08-07-2008, 05:55 PM   #5
thewrench3
What spark plug gap are you running? Mine did that when the plugs were gapped too wide. Its something simple and easy to check.
thewrench3 is offline   Reply With Quote
Old 08-07-2008, 07:37 PM   #6
Lou SG2340
Had a simular problem several years ago, tried everything. Replaced the delay box and every thing was fine. Who knows what causes it. It should be rf from some where. I know run a msd noise filter on the ing box.
Lou SG2340 is offline   Reply With Quote
Old 08-08-2008, 11:55 PM   #7
THE LEGEND
Had a tach on my stocker did that one time.
Had a crack in my blocke shooting water on a plug do that in my Hot Rod car one time.
A friend once said you will find a 100 things wrong but only one will fix it. I wanted to smack him.LOL
Chip
THE LEGEND is offline   Reply With Quote
