Old 11-08-2008, 02:55 AM   #10
Mitch Perkins
Mitch Perkins's Avatar
Default Re: To use a solid rear trans mount ?
We use the urethane mounts on every car built in the shop. With 1/4" front and mid-plates, or with the .090" mid-plates ( which I consider obsolete, 1/4" mid-plate helps to transfer torque to the chassis and the thin steel plates distort). Never had issues with breakage, However, the ones built with solid mounts at the least cracked the mounting bosses on the case even if the housing survived.
Mitch Perkins Perk-Bilt Race Cars
DragCoverage.com Staff Photographer
Mitch Perkins is offline   Reply With Quote
