Per my post on your Rod question ,,, I have run SB Chevys for over 20 years ( yea I'm Old
![]() I have run all the different blocks ,,, The one I perfer , and as a matter of fact I still have one new , never been used ( along with a lot of other SB stuff ) is a 2 bolt Chevy Bow Tie ( 2 bolt was thicker in the main area ) that has been converted to 4 bolt steel caps , boered to 4.130 ( I never take them all the way out to allow for future re-builds and boering ) decked , cleared for Groden Alumin Bilet 6"rods with a 3.750 stroke and 350 mains ,,, it was for a one piece seal crank but converted over for a 2 piece seal , so it can use any style crank. --- I bought it over 10 years ago when Chey used real metal ![]() ![]() ![]() ![]() ![]() Colorful Used to be SB racer !!
Eddie Arnold Jr. 3934 SC, SG |
eddie ...if you were to sell the short block how much ?
I usally attempt to get 50 cents on the $ ,,, Haven't given it much thought ,,, but like most folks , it wouldn't take much for me to sell specificly if it is to another racer who could really use the stuff and it helps him or her out Win / Win ---- I'll give it some thought and post a price list ,,,,, one caution is all parts are new except for Crank ( was repaired from spun bearing , checked , x ray etc ) heads and sheetmetal manifold .
(Heads were gone over and prepared , new springs etc by Watson Ruppel ) The pistons are new Wiesco Flat tops ( final compression was to be around 14.8 :1 ) but were made for heads with Valve releifs to comply with heads (23 degree exhaust and 18 degree Intake ) --- So I couldn't sell the short block with Pistons , but Pan , Block , Balancer , Rods , Cam , CSR water pump , crak trigger (distributer and pick up ) etc is all new still in boxes never used ,,,, I hadn't given it much thought because I was thinking of putting it together and seeing how fast the combination would be ( Martino had a 32x something and I was building a 401 !! ) --- Thanks for asking ,,, I'll follow up ! Colorful Racer
