Old 12-11-2008, 09:28 AM   #1
Freddie
Freddie's Avatar
Liked 3 Times in 2 Posts
Default Re: 8.90 hp
Back when S/C was just starting out, a friend of mine had a lil 331 Aluminum headed motor in his 1650# dragster and would run 8.8's all day long. We figured it to be somewhere around 575-600hp.
NHRA: Comp 2200 - S/C 2201
NMRA 2012 Outlaw 10.5 #10
Freddie is offline   Reply With Quote
Old 12-11-2008, 10:55 AM   #2
B CHILLIK
B CHILLIK's Avatar
Default Re: 8.90 hp
ive got a small block dragster weighs 1800 and it runs 8.70 all day,its only a 357cu motor roughly about 650 hp....
B CHILLIK is offline   Reply With Quote
Old 12-12-2008, 01:21 AM   #3
R&S Motorsports
Default Re: 8.90 hp
My uncle also has a name brand 4-link car with a roughly 675-725 HP 421 SBC and he runs 8.0's to high 7.90's depending on air. I was probley a little conservitive on my intial numbers I would assume just over 600 would get it done but 2000 pounds is pretty heavy for a dragster unless you are considering driver weight into that number.
R&S Motorsports is offline   Reply With Quote
Old 01-27-2009, 12:15 PM   #4
Freddie
Freddie's Avatar
Default Re: 8.90 hp
R&S: just curious, why would you not figure the drivers wieght in as well when determining how much power is needed to reach a certain E.T? Almost every class I have ever run car weight is calculated with driver. Just makes the total package wiegh less with a skinny driver ( unlike me )
