#41 |
Liked 53 Times in 16 Posts
These are the upper bushings I used in my 68 Impala I/S car. I got them from my friend Pat Henneberry, an old school racer from the sixties. he had these bronze bushing stock (which he used on his 68 Camaro Modified car which is still raced today) which I just had to chuck up on a lathe and cut to size for a press fit plus increase the center hole a little. These will be going in my 65 Impala stocker I am building now. These cost me $0 The front lower control arm bushing was a aluminum round stock which I chucked up on the lathe and machine to fit, pressed fit a bronze center bushing for the bolt to go through, which I also just added a grease fitting, they worked too. I have to make a new set for the 65 Impala.
Another high tech are the solid body bushings simply made out of that same aluminum round stock. They are 1/2 inch shorter than stock, effectively "lowering" the body 1/2 over the frame. I am glad I hang around guys like my friend Pat, they started racing when there wasn't a "Global West" or an Alf fella making all the parts for you. I fabricated a lot of parts and learned how to use a lathe, bridgeports and welders along the way. my 68 Impala was the first race car I built, people said It would be a parts breaker at 4100 lbs with a stick. Even though i only made 100 passes on car, no breakage with 7 tenths under. Will Lamprecht 1965 Impala H/I Stck |
#42 | |
Liked 226 Times in 76 Posts
Andy Friar |
#43 | |
Andy Friar |
#44 | |
Liked 282 Times in 78 Posts
Andy, That right there is the key! Anyone that states they have done it all and knows it all. Has not done anything and doesn't know ###t either. There are a lot of good people here to help you. Good luck Sean
#45 |
Thanks Sean!
Andy Friar |
#46 |
Andy, one thing I learned, I wanted to go Drag Racing, so I hung around drag racers, not baseball players, then I remained open, ask questions and overall remain teachable! When i think I know everything, I'm in trouble.
I also went to the track and looked at cars like mine. really looked, under and everything. Most everybody loves to talk about there cars and like to help. When i started running my 68 with the Jerico and McCleod clutch Jeff Lee (w the AMX) who post all the time on this forum helped me a lot, now i am looking for some help on how to run an Automatic successfully- I try to run my life remaining teachable too- your on the right track- Good Luck Will "Big 'ole chevy stocker" 65 Impala |
#47 | |
Just hope that both side "center" in the same place. You really want a ball type pivot on the bottom with a strut rod type suspension. Take a look at some of the stuff for early Mustangs or Chevy II's One other thing..THICKER body bushings give you more room between the carb and the hood.
#48 |
Liked 166 Times in 71 Posts
"Will, only problem I see with solid lowers is you can't pull the lower ball joint forward to gain positive caster..You'll have to do it all on the top.
Just hope that both side "center" in the same place. You really want a ball type pivot on the bottom with a strut rod type suspension. Take a look at some of the stuff for early Mustangs or Chevy II's" Doesn't apply to the chevelle. They use a conventional lower a-arm, no strut rod. You could get tricky and offset the center bore of the bushing if need be however.
Chris Chapman 1969 Chevelle NHRA F-G/SA 1090 |
#49 | |
I'm quoting Will with the full size 65 Impala
#50 | |
Andy Friar |
